Checking the Birdcage
Old Nov 30, 2007 | 04:52 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
Default Checking the Birdcage
Hi, I'm sure this has been posted before, but can anyone give me a quick lesson in inspecting the birdcage on a complete, all - together car? Also, the car is not mine, so I don't wat to be too intrusive. Any advice is appreciated. Stay safe, John
Old Nov 30, 2007 | 05:14 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
Anyone???????
Old Nov 30, 2007 | 05:23 PM
Bowerss2's Avatar
Bowerss2
i have heard that a rule of thumb is checking for rust stains around the door hinge bolts. However i dont know if this is any good or not. good luck
Old Nov 30, 2007 | 06:51 PM
jim2527's Avatar
jim2527
Check behind the front kick panels. Some dis-assembly of trim pieces is necessary. aside from from 'flake' which I didnt clean out before snapping the pic this would be considered good. There are bird cages in which this entire area is rusted/rotted to the point the body mount bolt is doing nothing.
This is behind the rear wheel well inspection plate. Again, as you can see, this is good.
Also, thoughly check the winshields lower corners. A bad birdcage sticks out like a sore thumb. If you have any doubhts snap some pics and post them here.
Old Nov 30, 2007 | 06:57 PM
Alan 71's Avatar
Alan 71
Why don't you search for some threads about birdcage repairs? That will give you an idea of where they usually rust and where to look. I always start by looking through the windshield from the outside at the windshield upper and lower corners. I also try to get a look in the wiper well. Does this car have a frame? Often birdcage rust and serious frame rust go hand in hand.
Regards,
Alan
PS: Getting 1 of the kick panels off to get a look at the hinge pillar is really needed, but not always allowed. I wouldn't buy a car with out seeing the pillars, and neither will you once you see the pictures in the birdcage repair threads. I think a car with a bad cage is worse than one with a serious hit.
gator79's Avatar
gator79
follow the advise and pull the kick panel trim it is only a few screws. if the owner objects walk away from that deal
Old Nov 30, 2007 | 07:21 PM
vettesbydesign's Avatar
vettesbydesign
John..alot of people may not be willing to let you remove a bunch of stuff,but you can see around the windshield area,and you can look between the rocker covers,and the frame side to see the bottom of the rockers,and the #3 mounts,if you can get it up on a jack,or ramps.You can also,go about it...if the owner isn't willing to let you pull the kicks,and the inspection plate for #3,then he doesn't want you to spend your money w/him......Found another one?I got your email..THANK YOU,and will get you the info. Call Steve?
Old Dec 1, 2007 | 01:10 AM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
Thanks alot for your help, especially taking the time to post the pics, i'll let you know how it works out, thanks, john
Old Dec 1, 2007 | 01:13 AM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
Thanks for all the advice guys, I'll let you know how it turns out on Sunday, take care, john
Old Dec 1, 2007 | 04:09 AM
RunningMan373's Avatar
RunningMan373
yep. pull the kick panels, there's one screw way in the back of the panel near the fire wall and then the covers in the front face of the wheel wells, wheels should come off. Here's a couple of shots of mine to compare with the others, mine would also be considered "good", the rust is all surface, Except for the LR, it's condition is questionable.
Edit: also take a look along the top edge of the windshield frame through the windshield, and down both sides, this is a high rust area too. also you can with 7 screws, 3 on top, two on each side, pull the pass side map pad carrier (whole face) and look at the underside of the front of the bird cage, it pulls right out, just a flasher cliped to it. And if you have a dig camera, you can put it into to front kick panel holes and take a pic up her skirt, to see the full condition of the metal.
RF
LF
RR
LR
Old Dec 1, 2007 | 07:18 AM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
That's alot RunningMan!
Stay safe, john
To Checking the Birdcage
