laquer?????
Old Dec 7, 2007 | 11:28 PM
onaqwst's Avatar
onaqwst
Default laquer?????
so i have a little project and sprayed it with some laquer in a spray can... think its duplicolor....got it at the paint store....... i believe i need to clear it.... if so, is there a clear in a spray can...... and how long do i need to wait before clear/base?..... i painted today but might recoat before i clear....
thanks
b
Old Dec 8, 2007 | 12:07 AM
Crazy81's Avatar
Crazy81
With laquers I've always had the best results when I let the color coat cure enough to wet sand it, then spray on the clear. House of color has a really nice clear laquer that does not yellow in time. I've also heard of people using urathae clear over laquer, but I have never tried it. The clear laquers are very easy to polish too.
Old Dec 8, 2007 | 12:09 AM
onaqwst's Avatar
onaqwst
does it come in a spray can?.... or you think i would have to buy a quart and have it canned?... i dont have a spray setup right now and project is due on monday
b
Old Dec 8, 2007 | 12:13 AM
Crazy81's Avatar
Crazy81
Last time I was at the paint shop, they said they were comining out with a line of rattle can laquers. I don't know that you could get it that quick though. How big is the item you are painting?
Old Dec 8, 2007 | 12:23 AM
onaqwst's Avatar
onaqwst
i got the laquer in a can... just want to get the clear in a can since the laquer shows any type of marks.............. picture a box about 6"x6"x27" thats about the size.... i went through 1.5 spray cans of laquer for it..... made sure it had some good coats........
project is for an architecture firm that i'm trying to hustle in some work from ...so i need to make sure the paint works out..... plus i just got the project in today and practically finished it up..just need about 2 more hours to complete
b
Old Dec 8, 2007 | 12:32 AM
Crazy81's Avatar
Crazy81
Another option is the local hobby shop. If they sell the Tamiya laquers there, you could use the clear. Only problem is it's expensive. It's about half the size of a large duplicolor can and cost about $4.50 a can. It goes on smooth and levels right out. Good stuff.
Old Dec 8, 2007 | 12:50 AM
onaqwst's Avatar
onaqwst
i know that theres an acrylic clear in a krylon... but i think that might now work...... not sure..... the paint store is open tomorrow till 12noon i think ...hopefully i can get it then
b
Old Dec 8, 2007 | 12:51 AM
noonie's Avatar
noonie
Duplicolor makes several clears in a spray can, 1 of which is a lacquer.
Check the 4th item down on the clear list.
https://www.paintscratch.com/cgi-bin/storefront.cgi
Here is another clear they make, but it's not as easy as laquer.
http://www.duplicolor.com/projects/howto_wheel.html
That gets you to their website anyway.
Should be able to find it at a big brand autoparts like Advance Auto.
You can spray the clear anytime after the color in lacquer. For full gloss, a laquer should be sanded lightly with 600 or above and buffed with compound after it has dried.
Always spray a test piece with your work and experiment with that first.
Old Dec 8, 2007 | 01:11 AM
onaqwst's Avatar
onaqwst
dool... thats what the other can looks like...... thinking that since the client wants a semi gloss look then maybe i wont have to sand the clear.... if i knew this would have taken this much time i would have added a few more bucks...........................
b
Old Dec 8, 2007 | 06:41 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Duplicolor makes a clear engine enamel that has a pretty good gloss and seems fairly tough...
Old Dec 8, 2007 | 06:53 AM
vettesbydesign's Avatar
vettesbydesign
I don't know about the rattle cans,and I'm not saying that this is a good practice,but I have seen it done MANY times over the years....as a rule.....you CAN spray urethane over lacquer,but no Lacquer over urethane.If you do go urethane over the lacquer...I'd mist the first coat,let flash very good,then mist another one,let flash,then give her a good dose.It's not a good practice to mix products,but I've seen it done.
Old Dec 8, 2007 | 12:55 PM
onaqwst's Avatar
onaqwst
i picked up a can of clear laquer today...... should be able to work with it tomorrow and get the project done......
question:
what is krylon...urenthane?
or rustoleum?....oil base?
i know you cant spray rustoleum over krylon since the krylon would get "eaten" up
i usually use krylon for the architecture models i do but think of swinging to another paint product for durability/looks
b
To laquer?????
