Broken Tap
Old Dec 9, 2007 | 08:05 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default Broken Tap
Well i had a stripped out exhaust bolt and drilled and tapped it. Well the tap broke while i was removing it. Has anyone had this happen. Can i get it out with a set of left haned bits and extractors? Thanks in advance
Old Dec 9, 2007 | 08:15 PM
gccch's Avatar
gccch
I've been there... on a MGB. I tried everything except a water jet. It was a threaded stud, so I ended up cutting one in half then welding it over the top of the tap. It was not in my engine block but on a exhaust manifold.
Old Dec 9, 2007 | 08:21 PM
Silver00V6Camaro
mines in the head on the exhaust so im hoping i can get it out with the bits and a extractor. it was not that bad i was at the very end had to run the tap by hand and the when i backed it out it felt like it was getting stuck so i ran it back in and then backing it out it seemed fine until it broke.
Old Dec 9, 2007 | 08:23 PM
...Roger...'s Avatar
...Roger...
The tap is hard so the drill wont work unless it just happens to spin it out.If you can make something to slide in the flutes you might be able to spin it. The tap is hard and brittle,I have used a punch before to break the tap into pieces as long as not too much is left inside.
Old Dec 9, 2007 | 08:29 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I've drilled them out with the gold-colored, titanium-coated bits. It isn't much fun, but it can be done.
Old Dec 9, 2007 | 08:32 PM
Silver00V6Camaro
my left handed bits are titanium coated so im hopeing i can drill it. Its not a big deal if i mess the threads back up I have another tap the same size and a bunch of helicoils to fix it. What about taking a propane torch to it?
Old Dec 9, 2007 | 08:35 PM
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
This happens at times at work mostly on aircraft engines. Tool of choice is a sharp center punch to break it in peices, you can try a pencil grinder with a carbide burr, it will grind it. lastly,, if you have the room, use the pencil grinder to gently grind around until loose,, but then you will have to oversize and insert a helicoil or rosan/kensert.
Old Dec 9, 2007 | 08:45 PM
Silver00V6Camaro
what about a dremel with a Tungsten Carbide Cutter.
Old Dec 9, 2007 | 08:49 PM
69FASTFUN's Avatar
69FASTFUN
Here is a link to some tap extractors
http://www1.mscdirect.com/CGI/GSDRVS...00000038240994
Old Dec 9, 2007 | 08:53 PM
Silver00V6Camaro
thanks for the link. Im trying to use things i have here at the house.
Old Dec 9, 2007 | 09:04 PM
Michel B's Avatar
Michel B
A dremel is good,, basically the same as a pencil grinder, the bur must be of very good quality,, carbide is a must, dip the bur in wax once in a while to lengthen its life, also don't let the bur over heat, control the speed. good luck
Tape extractors don't don't have a high success ratio, they are sometimes to delicate.
Old Dec 9, 2007 | 09:08 PM
bj1k's Avatar
bj1k
But it helps to heat the remaining piece of the tap with an acetylete torch with a fine tip on the torch. Try to keep the heat focused on the tap, this will take the temper out of the metal ( soften it ) and make it easier to remove either with a fine point chisel or by drilling out , but if you try to drill it make sure it is cool before drilling. I have removed many pieces this way without hurting the threads. Since there is very little of the tap remaining, this should work.
Old Dec 9, 2007 | 09:12 PM
Silver00V6Camaro
would a propane torch work. I think im gonna try the dremel. The drill is too hard to try and get in the tight area between the head and fender well thats using my 90 degree drill with the bits. I have the high speed cutters for the dremel so i will give it a try in the morning and see what happens.
Old Dec 9, 2007 | 09:43 PM
BigBlockTank's Avatar
BigBlockTank
bj1k, I have to disagree. If you heat the block, it will swell and loosen up the tap. Taps are hard enough that I don't think it will "untemper" the metal.
Old Dec 9, 2007 | 09:45 PM
Silver00V6Camaro
the tap is broke off in the exhaust on the head its not broke off in my block.
MikeMc71's Avatar
MikeMc71
If you have the part off the car, find someone locally with a sinker EDM and have the old tap burned out. It may cost you some $$, but its the BEST way to get the thing out.
Old Dec 9, 2007 | 09:47 PM
Silver00V6Camaro
everything is in the car. I do not want to take the head off of the motor.
To Broken Tap
Old Dec 9, 2007 | 09:59 PM
hicswa's Avatar
hicswa
EDM is the best way, I do it all the time at my shop. The tap is way to hard to drill if it is a good one. The drill will walk and attack the softer metal around it Burning it out won't cost all that much. If you can bring the part to a machine shop, with set-up and burn time should not be more than an hour.
Old Dec 9, 2007 | 10:02 PM
Silver00V6Camaro
would this work using the dremel
http://www.lowes.com/lowes/lkn?actio...94883-353-9931
read the above every thing is in the car. I do not and will not disassemble this motor. Its only a year old. The tap is the one that comes in the helicoil kits that you get at advance auto parts. stamped made in china in big letters on it.
Old Dec 9, 2007 | 10:10 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
A good punch will break up the tap, use a air hose to blow out the broken chips. Use a mirror to look into the hole to make sure it's clear.
