Two Inch Spacers (kinda off topic)
Old Dec 14, 2007 | 09:19 PM
lowbuck72's Avatar
lowbuck72
Default Two Inch Spacers (kinda off topic)
My son's got a set of '98 C5 chrome wagon wheels just taking up space, so I'm gonna try and put them on my 'ol Chevy van. Gonna use 2" bolt-on spacers, the good kind. My question is, can I depend on the original 7/16" studs to bolt the spacers onto, or do I need to uprade to 1/2" studs. What have you guys using spacers been doing? Are they safe and strong enough?
Old Dec 14, 2007 | 09:37 PM
Durango_Boy's Avatar
Durango_Boy
The best way is to get adapters that are hub centric. This means the hole in the middle of the adapter is designed to perfectly fit the outside diameter of the lip on the hub. That way the adapters are supported by the hub instead of the studs and the stud diameter won't matter.
However, switching to larger diameter studs is always a good idea, especially when putting after market rims on cars that old.
rcread's Avatar
rcread
Spacers or adapters?
Old Dec 15, 2007 | 10:06 AM
lowbuck72's Avatar
lowbuck72
They're both I guess. They've got 5 holes which attach to my hubs using chevy lugnuts. Then the have 5 studs in a chevy pattern sticking out to which I bolt the wheels, which widen the track 2". I am replacing 15X7 rims with a 4" backspacing, with 17 X 8 1/2 with a 7" backspacing in front, and hopefully the 18 x 9 1/2 will clear the rear leaf springs in the rear. The engine in my van is actually stronger than the one in my vette, and if it wasn't for the 3 on the tree, it would probably be well in the 13's. (old pic)
Old Dec 15, 2007 | 11:27 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Spacers just have holes for the studs to pass through. Adapters bolt to the hubs and have new studs for the wheels.
Spacers = dangerous.
Adapters = much safer.
Old Dec 15, 2007 | 12:00 PM
rcread's Avatar
rcread
Just curious - how did you paint your van?
Old Dec 15, 2007 | 03:54 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
just if you're interested, i have a PAIR of 2.5" VB adaptors i'm looking to part with. go to P/M if so.
Old Dec 15, 2007 | 09:33 PM
lowbuck72's Avatar
lowbuck72
My son t-boned a lady who pulled out in front of him about 5 years ago. I finally got around to welding on whole front clip. So I painted it with rustoleum using a brush. Looks ok from 10 feet away.
Old Dec 15, 2007 | 09:47 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Vans, a blast from the past. I remember my uncles van. It was a panel van with some heart shaped windows. It must have been a van sometime from the 70s. Yours is pretty cool looking. Looking forward to seeing the pics with the new wheels.
To Two Inch Spacers (kinda off topic)
