Rocker Panel Question
Old Dec 21, 2007 | 11:13 PM
FRSTR90's Avatar
FRSTR90
Default Rocker Panel Question
On some the original rocker panels is there a part that is wavy on passenger side? The reason why I ask is because I have a NOS rocker panel that has this wavy area about the size of a nickel. I just saw a pair of rockers for sale and I believe the are they originals and they look as if the have a wavy spot in the same area. I am assuming that this rocker is not a repro because it has GM wrapping paper around it. I could take pics if it would help.
Also, do original rockers have a part #. I cant seem to find a part # anywhere. I only have the right side and I am missing the left (maybe the part number is only on the left?)
Any info would be great thanks!
Old Dec 22, 2007 | 12:32 AM
SEVNT6's Avatar
SEVNT6
I replaced my left rocker, which I kept & it doesn't have a number on it...
I didn't notice any waves on my right one. Just where is it at?
Old Dec 22, 2007 | 02:03 AM
FRSTR90's Avatar
FRSTR90
At the back of the door opening where it starts to curve back down. I'll get a pic.
Old Dec 22, 2007 | 10:54 AM
avner's Avatar
avner
I have 72 original rocker panels with the tabs on front out of the car (frame off restoration) and there are no wave & no part #.
I think that from 1973 the rockers come without the tabs at front.
What rocker you have?
Avner
Old Dec 22, 2007 | 11:43 AM
FRSTR90's Avatar
FRSTR90
Here is the pic.. Hopefully you guys can see what I am talking about..
Old Dec 22, 2007 | 11:44 AM
FRSTR90's Avatar
FRSTR90
Avner
Aren't all rockers from '70-'77 the same??
Old Dec 22, 2007 | 12:22 PM
SEVNT6's Avatar
SEVNT6
I just checked mine and guess what? I have two small waves just past the next to last screw. And since I bought mine new & I know it's never been damaged it had to come like this....
The repo I got on the left side is perfect.....
Old Dec 22, 2007 | 04:25 PM
7T1vette's Avatar
7T1vette
The factory parts can have some wavy areas in them. The aluminum panels were stamped. When they are stamped, the metal is stretched and heated...more so in some areas than others. My '71 had original panels [until I accidentely trashed one and had to replace it], and both had a couple of small wavy areas in them at the same general location.
Old Dec 22, 2007 | 04:41 PM
FRSTR90's Avatar
FRSTR90
Very cool! When I first saw the 2 waves, I was a little disappointed and kind of POed. Since it came like that from GM, I am actually happy that its there(weird, huh?). I guess this is one way you can tell if you have authentic GM RH rocker panel. I wonder if NCRS judges know to look for this
So, the left side has them too?
Old Dec 22, 2007 | 04:52 PM
FRSTR90's Avatar
FRSTR90
I am now having doubts if there is anyway you can tell if you have a NOS item or a repro panel. I looked at my dad's '73, and he replaced the panels in '82 and there was no wave. At this time the NOS parts were new replacements. Would NCRS judges take points off for having or not having the wave?
Old Dec 22, 2007 | 05:04 PM
bj1k's Avatar
bj1k
I bet if the auto workers would have known it was a good thing to put defects into making a corvette, they wouldn't have put any care into building them at all. What has this come to ? Overspray is good, dents are good ? Next someone will be duplicating dents in the right side rocker panels and selling them on ebay for $500.
Old Dec 22, 2007 | 05:08 PM
SEVNT6's Avatar
SEVNT6
Mine did. Same place too....
Old Dec 22, 2007 | 06:03 PM
FRSTR90's Avatar
FRSTR90
Defects are never good and that was not my point... I was going to trash that rocker panel which is a NOS item that has never been installed. I am quite picky and knowing that those 2 waves were there would have sent me off the wall. When I start building my '73 project (if the time ever comes), I am going to make sure I get the rockers with absolutely no dents. When I get that car done, I plan to restore my DD back to NCRS since it so complete and is virtually all original then I would install this rocker. My '73 DD still has the visable seams and is supposed to have the original paint (which I don't believe it does). Thats a defect from the factory, do I like them there? (rhetorical question - answer is no for if didn't know) However, I am glad that they are there because it is "correct." We have to admit that these cars didn't come from the factory perfect. Not all the doors, hood, and etc. line up as nice as the do on the C4's C5's and C6's. Hope you understand what I mean..
On a side note, do the rocker panels not have a part #? I find this rather strange..
Old Dec 22, 2007 | 08:44 PM
7T1vette's Avatar
7T1vette
I'm sure the rocker panels have GM part numbers assigned. However, in that era, GM wasn't so concerned with aftermarket companies "stealing" their replacement parts business...they were the only game in town. So they didn't put part numbers and logos on all parts like they do today, but only on the parts that could be marked during their normal processing (casting, injection molding, etc). If they had done so on the rocker panel, the number would have been stamped into the front surface [not too attractive]. Today they have laser etchers which ID everything on non-cosmetic areas.
Old Dec 23, 2007 | 12:45 AM
early shark's Avatar
early shark
Yes, there is an ink stamped part # on the inside of the body sill mouldings. It is very faint, lightly stamped, and difficult to see/read with corrosion that occurs on the inside surface of these mouldings from age/climate elements. The numerals are about 1/2 inch tall. They are located about 4 inches from the end side that is closest to the front of the rear wheel well.
Old Dec 23, 2007 | 12:00 PM
avner's Avatar
avner
No
70-72 with the tab at front & 73-77 are without the tab.
72 Assembly Manual parts #: 3966607, 3966608
To Rocker Panel Question
