Da Sander Or Block Sand ?
Old Jan 7, 2008 | 10:15 AM
blackbeauty74's Avatar
blackbeauty74
Default Da Sander Or Block Sand ?
Can someone tell me if it is ok to use a DA sander on our cars? Or is it best to block sand when taking off layers of paint? My wife gave me a gift card to Sears and I've always wanted a DA Sander.
Old Jan 7, 2008 | 10:50 AM
Durango_Boy's Avatar
Durango_Boy
If you use a DA, make sure you're very good with it, don't use aggressive grit paper, and stay away from ridges.
It's BEST to block, but it is possible to use a DA on these cars. It's also possible to create a whole lot of extra body work by using one.
Old Jan 7, 2008 | 10:51 AM
blackbeauty74
thanks.
Old Jan 7, 2008 | 11:11 AM
lars's Avatar
lars
You can never get a straight body panel using a DA. You can use the DA to strip the paint off and work the repairs. But to get a smooth panel, you have to block the car - you can't finish the car using a DA.
Old Jan 7, 2008 | 11:15 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Never use a DA on fiber glass unless you want a mess.
Old Jan 7, 2008 | 11:30 AM
gyopp's Avatar
gyopp
The DA can save you a lot of work if you are very carefull or you can make yourself a whole lot more work. I stripped my paint and inteded to block the rest of the way but found that I had lots of layers of primer. I used the DA to get down to the lower layers and then started hand blocking. As said before, stay away from edges.
Old Jan 7, 2008 | 02:02 PM
capecorvette's Avatar
capecorvette
I da'd my car down to the glass. After I prime it I will block it by hand. But I know how to use a da, if you don't have experience, you will get into trouble. I cant imagine trying to block paint and primer down you will be an old man by the time you are done. I da'd my car down in 2 days of time, basically 1 weekend.
Old Jan 7, 2008 | 08:49 PM
onaqwst's Avatar
onaqwst
razor/stripper/long board
Old Jan 7, 2008 | 09:02 PM
Durango_Boy
I like that middle one...
Old Jan 7, 2008 | 09:23 PM
Tony24's Avatar
Tony24
Default Layers
When you say taking off layers of paint (How many?). Are you trying to get to the primer? Or, just trying to create a smooth physical surface for the paint to stick.
Old Jan 7, 2008 | 09:39 PM
FB007's Avatar
FB007
Old Jan 7, 2008 | 09:45 PM
swtato's Avatar
swtato
St. Jude Donor '05
I have been using the razor and DA sander in areas where the razor was not working and it has worked fine as long as you do not stay in one space. Just pay attention and keep moving.
Old Jan 7, 2008 | 09:59 PM
hicswa's Avatar
hicswa
You can use a 3/16 da with 400 grit to prepare the surface for primer, but then I would use a block and guide coat to flatten the surface. If you are experience you can than use a 3/32 da with 1000 grit if you have a lot of trash in the paint and if not, go to 1500, 2000, and so on.
Tape all the edges with autobody painter tape so you don't burn through. You must make sure to keep the paper on the da clean or you will get pigtails in the paint. That were the experience come in. Pressure on the da, speed, grit of paper will all have an affect on the outcome. Don't use an electric da. I don't know what they orbit at but, they are hard to control compared to the air driven type. Yes it can be done, but, key is to start with a flat surface. You are also going to need an interface pad on the da.
Hope this helps,
Danny
Old Jan 7, 2008 | 10:34 PM
dbeall1968's Avatar
dbeall1968
Old Jan 8, 2008 | 12:15 AM
Aggitated Monkey's Avatar
Aggitated Monkey
I have used a DA on vettes and you must be carful and keep it mooving. Do not try to force work an area. When you are done you will have to block/longboard
Old Jan 8, 2008 | 09:49 AM
blackbeauty74
Thanks for all of your input. I think Im going to stay away from the DA.
Old Jan 8, 2008 | 11:30 AM
7T1vette's Avatar
7T1vette
Just curious.. has anyone ever stripped the hardware, then taken it to a body shop for body paint strip prime and prep, then masked and painted yourself? If the shop is willing to do it, why not? The painting would be easier than strip/prep portion.
To Da Sander Or Block Sand ?
Old Jan 8, 2008 | 11:38 AM
Durango_Boy
Kind of. There is a lot of prep work to be done between coats of both the paint the clear. Doing it that way won't save you all the work, but it'll lighten if some if you don't mind paying the shop to do some of the work.
Old Jan 8, 2008 | 12:18 PM
steve228's Avatar
steve228
Well,You can still use the gift card to get a DA.They do come n handy.Steve
Old Jan 8, 2008 | 01:48 PM
66roadster427's Avatar
66roadster427
I found an air line sander worked the best when i stripped the 60 and the 66.
here is the one I use ( http://www.oreillyauto.com/EW3/exter...mageViewer.jsp )
