Will an alignment fix this? (pics)
Old Jan 7, 2008 | 07:30 PM
rajsid's Avatar
rajsid
Default Will an alignment fix this? (pics)
The tops of the rear wheels on my 69 are pointed in. Is this an alignment problem or does it need a complete rebuild?
I dont know how to go about troubleshooting this.
Is there a sequence of things to do to fix this by eliminating the most obvious causes.
Thanks in advance.
Old Jan 7, 2008 | 07:34 PM
73339's Avatar
73339
Thats negative camber. Looks around 1.5 degrees
What condition are your lower strut rods in?
Old Jan 7, 2008 | 07:36 PM
1982CorvetteDude's Avatar
1982CorvetteDude
I was told by my alignment shop your going to have some negative camber, it's the way those suspensions were designed.
An alignment should take some of that out..it's an adjustment bolt.
Old Jan 7, 2008 | 07:37 PM
rajsid's Avatar
rajsid
It looks good just by looking at it. No rust or bent.. If that's what you wanted to know. How do you fix the camber?
Or am I better off taking it to an alignment place?
Old Jan 7, 2008 | 07:38 PM
dannyman's Avatar
dannyman
Let's see a picture under the rear of the car. Would be helpful to see the position of half shafts. Are they horizontal??
Old Jan 7, 2008 | 07:44 PM
73339's Avatar
73339
Thats a bit excess
Look and see if the bushings are worn.
Old Jan 7, 2008 | 07:45 PM
rajsid's Avatar
rajsid
Good idea..
I will post some as soon as I get home from work.
Old Jan 7, 2008 | 08:06 PM
Retro78's Avatar
Retro78
Most common causes are either (A) worn strut bushings or (B) worn diff side yokes.
An alignment will correct your wheels back to a slightly negative camber(you have too much).. . but it wont fix the underlying issue.
My suggestion is to inspect the bushings and side yokes before doing anything.
Old Jan 7, 2008 | 11:12 PM
rajsid's Avatar
rajsid
Guys,
Here are some pics of the rear. The PO had replaced the rear end recently. Not sure if he replaced the bushings or the yokes.
Old Jan 8, 2008 | 02:29 AM
Steve COSD's Avatar
Steve COSD
The rubber bushings on each end of the strut rods take a relaxed fit after time and this can be the cause. Vette Brakes and Products make a bushing kit that is made out of urethane. This will fix the rubber bushing problem. Also you may need a 4 wheel alignment. C3s can be very finicky in this area. Ask your local Corvette Club who they deal with. A good alignment can take 2 to 4 hours and cost $80 to $150. A good aligment can make a C3 enjoyable to drive and save you money on tires.
Goos Luck
Steve
Old Jan 8, 2008 | 06:22 AM
KALAWAY's Avatar
KALAWAY
It would be nice if someone knew if these cars came from the factory like this. I've seen so many with negative camber that I'm thinking the rear suspension is designed that way. Mine looked the same way until I replaced the rear spring. The wheels straightened up considerably. This makes me think the wheels should be straight.
Old Jan 8, 2008 | 07:06 AM
corvetteload's Avatar
corvetteload
Take it to a good alignment shop, they will have the factory specs for rear alignment for a 69. My 69 when I first got it had the wheels pointing out like that, and every bump or dip I hit in the road felt like the car was bottoming out. I took it to a local alignment guy and when I got it back the wheels looked perpendicular to the ground and the ride was VERY MUCH improved. It's worth it to you to just take it and find out......................B
Old Jan 8, 2008 | 08:39 AM
rajsid's Avatar
rajsid
Thank you all for the valuable responses.
Old Jan 8, 2008 | 09:17 AM
myk7's Avatar
myk7
Yup, it may be an optical illusion, but this bushing seems to be totally shot.. or missing
Old Jan 8, 2008 | 09:30 AM
Wuttin's Avatar
Wuttin
Nice Pix. I agree to get it aligned. You should have very slight, almost unnoticeable negative camber when aligned properly.
The good news:
It looks like your differential side yokes are in good shape (no seepage of fluid onto the diff, plenty of clearance between the diff case flanges and the u-bolts heads, so they're not suspect
You still have adjustment left on the eccentric cam where the strut rod meets the mount below the differential. A good shop should be able to dial it in without any creative repairs (for instance, when the cam has been set to its max adjustment bubba tends to heat and bend the strut rods up to make up the difference...joy).
In my limited experience I have to say that a quality alignment did more to improve the ride and my enjoyment of the car than any other maintenance/mod I've done so far. Find a qualified shop with lots of experience with C3's and 4 wheel alignments...I've heard people claim it is a lost art. Make sure they have a solid record of aligning C3's and ask for references. Don't skimp and take your time finding a shop.
best of luck, Steve
Old Jan 8, 2008 | 10:13 AM
PETKAH's Avatar
PETKAH
My '70 has the same thing. But, in my case it is the bearings. Do a
bearings test before you spend any bucks. Might need a new spindle
too.
Old Jan 8, 2008 | 11:13 AM
7T1vette's Avatar
7T1vette
Optical illusion? He!!, I'm lookin' right at it! [Think about it.]
Seriously, the stock specs for rear camber is just a bit slightly off nominal [zero] to account for driver/passenger weight when in use. The amoun't shown in your pics is way off. How the car gets set up depends on how the shop did the alignment. A good shop will ask you how you want the rears set up: adjust it for ONLY the driver weight; for driver & passenger; for driver and full tank of gas; etc. Since I am the only person in the car [usually] and try to fill up the tank when I get to 1/2 full, I get the rears set up for driver weight ONLY and bring it to the shop with about 3/4 tank of gas. Some shops even have a weight bag to put in the driver's seat so that the set up is more easiy accomplished.
Old Jan 8, 2008 | 01:09 PM
Darrel1's Avatar
Darrel1
Guys,
Looks like in that top picture you still have room to adjust the camber with bolt.
Darrel1
To Will an alignment fix this? (pics)
