Trans -go **** Kits
Old Jan 15, 2008 | 12:25 AM
76 VETTE's Avatar
76 VETTE
Default Trans -go **** Kits
Have heard a lot of good things about these kits.Any one install one and how do you like it? Thanx...dale
Old Jan 15, 2008 | 12:28 AM
1981Z06Vette's Avatar
1981Z06Vette
They can be a PITA to install if you aren't comfortable with auto transmissions, but I have been happy with them (installed in both a TH700R4 and a 4L60E).
Old Jan 15, 2008 | 11:58 AM
76 VETTE's Avatar
76 VETTE
They are supposed to come with a video to help with the install.No special tools.I have a front seal leak and need to drop it anyway and thought about one of these kits. Don't know where the stars came from in the thread title.The mods must have added them for some reason.
Old Jan 15, 2008 | 12:14 PM
SIXFOOTER's Avatar
SIXFOOTER
Mine didn't come with a video, but the instructions were very clear and the kit was well organised, no problem installing it at all.
Only way to go IMHO
Old Jan 15, 2008 | 12:15 PM
SIXFOOTER's Avatar
SIXFOOTER
Did you misspell SHIFT in the original post?
Old Jan 15, 2008 | 12:22 PM
76 VETTE's Avatar
76 VETTE
Could be Six.I tried to find original post to see if I did. Wasn't intentionable.
Old Jan 15, 2008 | 05:02 PM
Scott Marzahl's Avatar
Scott Marzahl
Very straightforward job, no video with ours either. Unless the trans is out and on the bench, the biggest pain is the occasional tranny fluid dripping on you, other than that it's pretty easy.
Old Jan 15, 2008 | 06:11 PM
76 VETTE's Avatar
76 VETTE
Sounds like it's something I want to do.Have heard nothing but good. Nice add on for $81 bucks.Thanx for the info. ....Dale
Old Jan 15, 2008 | 07:41 PM
shoptek's Avatar
shoptek
If it is the same kit as I installed......
Pay special attention to the placement of the ball bearings (check ways) on reinstallation of the valve body spacer.....Don't ask me how I know.....
Old Jan 15, 2008 | 07:55 PM
76 VETTE's Avatar
76 VETTE
I just ordered the one from Sumitt for a 350th. It is supposed to come with a video.Is yours a 350th?
Old Jan 16, 2008 | 06:27 AM
guitarcrazy02's Avatar
guitarcrazy02
What exactly does a shift kit do? My dad has one on his camaro, and it definitely shifts harder than a stock one, but how does it work?
Does it shorten the life of a tranny?
Old Jan 16, 2008 | 09:13 AM
Maymyvetteliveforevr's Avatar
I had my Trans Go Shift Kits installed at a Tranny Shop many years ago and it works great. As for the life expectancy of the Tranny, the shop told me that that when you set it up, the harder the shifts the more strain on the tranny. He wouldn't give me details.
Old Jan 16, 2008 | 09:50 AM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Cause he didn't know what the heck he was talking about. Slow, cushy shifts (hallmarks of normal GM TH) cause more heat build up than quick shifts. This is not metal gears moving around like when you slam shift your 4-speed, it's hydraulic pressure applying bands & clutches. Unless sequence or timing are off, you can't shift an auto too fast.
Old Jan 16, 2008 | 10:30 AM
76 VETTE's Avatar
76 VETTE
Not sure how it works but have read that it is actually easier on the tranny than running without one.They would have put one in at the factory but most like the smooth shifts.
Old Jan 16, 2008 | 04:32 PM
guitarcrazy02
So what exactly is it. The low price, relative ease of installation, and payoffs have me drooling. Tell me more...
Old Jan 16, 2008 | 05:31 PM
Scott Marzahl
Simply put, you reprogram the shift points and pressures by installing different springs in the valve body. You can also do manual shifts or use the auto mode.
Here is a description from B&M:
http://webbcon.com/patio/b&m2.html
Old Jan 16, 2008 | 11:50 PM
RIJVETTES's Avatar
RIJVETTES
Definitely one of the very best modifications on my TH350- fast and firm shifts without the lazy cushy lag. Almost like a stick without the clutch. Increased fluid line pressure does the trick. I previously had one installed on the 700R4 on my 93 when I owned it, and was sold on Tran Go. Much more fun to drive!
To Trans -go **** Kits
Old Jan 17, 2008 | 01:13 AM
str8upchevy's Avatar
str8upchevy
From: 90% of all Fords are still on the road.....the other 10% actually made it home!
Yes, these kits are definitely the way to go if you have a stock TH350. I've run the Trans-Go kit in most all my automatics without ever having a problem with a single one. But as mentioned already, be really careful when you're putting the valve body back up into the tranny so that those little ball bearings don't roll out of the selected holes. (Been there, done that too)
I just bought another one of these kits last week for my '81 project, since I'm putting a new small block 406 in it this month. I'm also going with a 9.5" 3000 stall converter, so the shift kit's a must!!!
The other nice thing about these kits is the ability to hold 1st and 2nd gear to any RPM you want. It also allows you to down shift at any RPM as well.
Old Jan 17, 2008 | 01:33 AM
Manuel Azevedo's Avatar
Manuel Azevedo
For the most part shift kits do increase the life of the clutchs. They do increase line presures some but the reprogaming of the shifts is what really makes it shift better. They do that by seperating the shift points. Meaning a stock trans leaves the trans in say frist gear and then applies second then releases frist gear there for makeing a smooth shift. So if you release frist gear and then applie second it feels much harder and makes a lot less heat and less wear of the clutches, Hope I didn't make that to confusing. Remeber when working on an antomatic that you can't make things to clean, dirt is one of the biggest killers besides heat in an automatic trans. Good luck with this project.
Old Jan 17, 2008 | 06:21 AM
guitarcrazy02
You can downshift at any RPM? well, within reason, I suppose...
I have to get one of these!
