CE Engines
Old Jan 17, 2008 | 09:10 AM
stingr69's Avatar
stingr69
Lots of misinformation about the meanings of "CE". It is used for "Chevrolet Engine". If you bought a transmission over the counter it would have been stamped "CT" for Chevrolet Transmission. If it was a Pontiac replacement engine it would be "PE", etc.
-MArk.
Old Jan 17, 2008 | 09:58 PM
Tom73's Avatar
Tom73
This is from the Mortec site (www.mortec.com):
There is another type of stamping found on some blocks. This is the "CE" code. You might see something like this "CE123456" on the front pad of the block deck on the passenger side. The "CE" which alternatively has been known to stand for "Chevrolet Engine" or "Crate Engine" was used on blocks that were warranty replacement motors. The "CE" prefix was also used on "over the counter" blocks and engines. If a customer had problems with his original motor, while it was under warranty, it was replaced with an engine that was stamped "CE" with a number of numeral digits following it which serialized that particular engine. Likewise if a purchaser bought a new motor from the Chevrolet Parts counter, the front pad on the pasenger side of the block may have been stamped with a "CE" code.
