CE Engines
Old Jan 16, 2008 | 07:25 AM
MikeMc71's Avatar
MikeMc71
Default CE Engines
Where can I get the "real" low down on CE engines, or is this just a GM mystery that will never really be solved?
Old Jan 16, 2008 | 07:51 AM
Durango_Boy's Avatar
Durango_Boy
Just do a search for Chevrolet Engines, and you'll find some good information. I just did a Google search and found some good stuff.
Old Jan 16, 2008 | 07:58 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
What mystery? CE engines were just the over-the-counter and/or warranty replacement engines in the 70s (and maybe the 60s and early 80s).
Old Jan 16, 2008 | 10:10 AM
markdtn's Avatar
markdtn
what he said. Warranty on powertrain was good for the day. You blew up the motor under warranty, you got a new one. Lots of these cars had just such stuff done. No mystery to it.
Old Jan 16, 2008 | 10:42 AM
7T1vette's Avatar
7T1vette
There may be something called Competetive Edge now, but CE on "Chevrolet Engineering" spare-parts blocks is just how the GM parts system kept track of those blocks for continuation of warranty coverage after using them for replacements.
Old Jan 16, 2008 | 11:22 AM
MikeMc71's Avatar
MikeMc71
OK...this is the reason, I just bought a VERY clean '71 LT1 coupe from a very nice guy that had owned it since 1985. He had the engine rebuilt in 1992 by a GM buddy of his, the engine he got with it was a CE engine. He has not driven the car since 1997 because of health issues. This thing is ALL LT1, the ignition is right, the intake, carb, heads, transmission, HD rear, welded crossmember are all right.
I am trying to rersearch this block, and all the stuff I can find says that when they changed the block they made them for the application. SO, this is actually a 1973 LT1 block. The number is strange also: CE3A84. Nothing I can find says what the "A" is, or even if its supposed to be there.
OH....the car was never registered or titled until 1973, which just adds to the mystery!
Old Jan 16, 2008 | 12:20 PM
Mike Ward's Avatar
Mike Ward
I still don't see much of a mystery. CEs (Chevrolet Engine) were supplied over-the-counter for sale to anybody,as well as warranty replacement engines for many years.
There's no such thing as a specific 'LT1 block' for any year, they're all the good old 0010 casting number used on every Chevrolet for about a decade.
You'd have to disassemble this engine to find out what's inside.
Old Jan 16, 2008 | 01:01 PM
GD70's Avatar
GD70
There was no 73 LT-1 block. The L-82 was it's replacement.
Old Jan 16, 2008 | 02:25 PM
stingr69's Avatar
stingr69
The block he has is a service replacement that was cast and assembled in 1973. There is no way to know what the application was or even if it was an over the counter sale or a warranty replacement. You can tear it down to see what is in there and that is the only thing you will ever find out without paperwork.
You could buy an LT-1 "CE" engine in the '70's and even later. They were available for purchase through the parts department or as a warranty replacement.
-Mark.
Old Jan 16, 2008 | 02:51 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
-Mark.
And in fact, someone has an unused one, still in the crate, available in the Parts forum right now.
Old Jan 16, 2008 | 03:02 PM
MikeMc71's Avatar
MikeMc71
First of all...thanks for all the responses. Because it has sat so long, I will be changing all of the fluids, and I will pull the oil pan and have a look inside. It is a solid lifter engine, so we shall see!
By the way...this is it:
Old Jan 16, 2008 | 03:58 PM
7T1vette's Avatar
7T1vette
Very nice. The car may have been an LT1 originally, but the engine you have could not have been a warranty replacement...simply because the warranty on your car would have expired before that blockwas even cast. It could have been an over-the-counter replacement for an "original" engine gone bad and replaced by a dealer or the owner. Or it could be that someone bought up that engine and stuck it in a non-LT1 car to turn it into an LT1-clone. Without the original paperwork on the car and/or the CE engine, I don't know how you could find any of that out.
Old Jan 16, 2008 | 04:23 PM
early shark's Avatar
early shark
Nice looking car. You don't see classic white with dark blue interiors very often. We don't even have that combination in a 1971 LS6 Corvette in our survey/registry yet, (we now have half of the production known).
Currently I have the only known classic white with red interior LS6 Corvette. I like unusual color combos, it makes the cars a bit more interesting.
Old Jan 16, 2008 | 04:52 PM
Aggitated Monkey's Avatar
Aggitated Monkey
A nicely preserved Corvette. Hope to see more of it
I do need to ask what asre those heater hoses? Garden hose?
I just never seen green auto water hose.
Old Jan 16, 2008 | 05:37 PM
MikeMc71's Avatar
MikeMc71
Those are from Gates, some kind of heavy duty heater hose, I'll be going back to black!!
Old Jan 16, 2008 | 08:46 PM
'75's Avatar
'75
Those heater hoses are silicone, top of the line.
Old Jan 16, 2008 | 09:04 PM
wfo76's Avatar
wfo76
The 5/50 powertrain warranty was discontinued around late 70 or early 71 so this could have been a warranty engine on an early car.
To CE Engines
Old Jan 16, 2008 | 09:11 PM
SmokinBBC's Avatar
SmokinBBC
The original engine type that came with the car will be listed on the tank sticker. Have you checked to see if it is still there?
Old Jan 16, 2008 | 09:29 PM
FOLDNTOP's Avatar
FOLDNTOP
From: Oakville ON "Real Corvettes have folding tops..."
Tank sheet would be good document as to original equipment. It was always my understanding that CE was for "crated engine" and purchased through parts or warranty replacement. Picture of the engine compartment looks like a 71 Lt-1 missing the ignition shielding. Rocker covers are also right for 71 LT-1 Vette...Enjoy the car!
Old Jan 16, 2008 | 09:53 PM
69camfrk's Avatar
69camfrk
From: GA "When I grow up, I'm gonna get a Trans Am and run from the cops". Direct quote from my 4yo son.
All I've ever read said that CE=Counter Exchange. Hmmmm..
Did some more research and it said CE stood for Chevrolet engine. But was also called counter exchange, counter engine, and crate engine.
