Engine stamping
Old Jan 25, 2008 | 06:49 AM
pwsusi's Avatar
pwsusi
Default Engine stamping
I know it's hard to tell from one picture, but want to get some opinions on this stamp..
Thanks,
Paul
Old Jan 25, 2008 | 08:02 AM
Deron's Avatar
Deron
I know there are better experts out there, and I am not one of them, but it to me it looks looks like the stamp bounced.
Old Jan 25, 2008 | 08:06 AM
mstanton's Avatar
mstanton
It's hard to tell in the picture. I can't really see broach marks but I'm far from an expert on that subject. The 0 in the V0225CTU is slightly different from both 70 LT-1s that I have owned, but I think they often used 0s and Os interchangeably. The inconsistency that I see is the VIN derivative should start 70S4 not 10S4. Both 70s I owned started 70 for the year and according to NCRS Tech Man, all should. Mistakes were often made on the line, but that seems like a pretty big one to me. What is the body build date? Based on the VIN, that would be one of the last CTU LT-1s built. What else do you know about the car?
Old Jan 25, 2008 | 02:27 PM
pwsusi's Avatar
pwsusi
the car is on ebay now and was listed one time before not to long ago. i don't know if it's legal to post links to ebay but I'm pretty sure it's the only '70 LT-1 up right now. The first time up for auction the this was the picture of the pad that was provided.
I don't know it was chrome plated or if he did some weird effect in photoshop or something in an attempt to get it to show up better? Either way it just doesn't seem right to me. I don't see the bounce on the "1" in this picture either.
auction numbers are
290194433159
and
290201385024
Old Jan 25, 2008 | 02:42 PM
gccch's Avatar
gccch
Paul,
To me, this may be a legit car, and may be the right engine, but for sure it has been restamped. Some of the dates are questionable. The build date on my '70 is 3/18 with the engine 3/05. Why it would be such a large time gap on this one I would not have a clue. I suppose it could have gone back for rework but in my mind this one was stamped at least once, maybe twice.
Greg
Old Jan 25, 2008 | 05:29 PM
Alan 71's Avatar
Alan 71
I'm wondering about the broach marks, too.
Regards,
Alan
Old Jan 25, 2008 | 05:55 PM
nutsy's Avatar
nutsy
what do broach marks actually look like? what do i look for?
Old Jan 25, 2008 | 07:10 PM
joewill's Avatar
joewill
broach marks, the stamp may not be great but the broach marks stand out...
Old Jan 25, 2008 | 07:21 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
MY PAD
Old Jan 25, 2008 | 08:11 PM
mstanton's Avatar
mstanton
Both of the pictures with obvious broach marks are big blocks. I believe that broach marks stand out clearer on big blocks, especially in pictures. The time gap between the engine and car build is a little long but I don't think so long that it should be a red flag by itself. At that time the last of the CTU engines were being used and that may explain the gap. Again, I think the biggest thing that needs to be explained is why the VIN starts with 1 vice 7.
Old Jan 26, 2008 | 09:54 AM
pwsusi's Avatar
pwsusi
how uncommon is it for one of the stamps to be upside down?
Old Jan 26, 2008 | 11:20 AM
7T1vette's Avatar
7T1vette
Severity of "broach marks" is a function of how old the broach bar is. After so many passes, those bars go back for sharpening. After sharpening, they generate a smoother appearance...then wear till the marks get pretty obvious. Don't expect the same appearance on every engine...it doesn't happen that way.
Old Jan 26, 2008 | 01:24 PM
nutsy's Avatar
nutsy
7T1, glad you cleared that up. i got a 72 bb and barely can pick up some marks. thought maybe something funny here.
Old Jan 28, 2008 | 08:39 AM
pwsusi's Avatar
pwsusi
any thoughts on the picture in my last post with the upsidedown stamping? Did some come from the factory like this, or is it perhaps a sign of a restamp?
Old Jan 28, 2008 | 09:38 AM
7T1vette's Avatar
7T1vette
Just a guess... but I would bet that anyone trying to make it appear original would know which way to stamp the block. It's more likely that some "newbie" in the machine repair ranks installed the stamping equipment upside down. Now that you have mentioned it, I would imagine that others [with similar condition] will be commenting about that.
Old Jan 28, 2008 | 08:32 PM
mstanton's Avatar
mstanton
Maybe never even noticed in the factory.
Old Jan 28, 2008 | 10:15 PM
427SIXPACK's Avatar
427SIXPACK
.............Or even gave a SHYT
To Engine stamping
Old Jan 29, 2008 | 02:58 AM
Z-man's Avatar
Z-man
OK - something is not right with pwsusi's head number. That pad stamp should be identical to all but the first four digits of the vin number. The first two digits should be 71 because it's a coupe (7) made in 1971 (1). I hate to say it, but it looks double stamped in the 1 area. The suffix of CTU is correct for an LT1. Maybe it's from a different year...
Here's the what the code from a vin should look like...
1 - Chevrolet (Line)
94 - Corvette (Model)
37 - Coupe (Body style)
1 - 1971 (Year)
S - St. Louis (plant)
4 - can't remember what this was
08532 - manufacturing sequence number (serial number)
Decode Link
1970 used the same engine coding as 1971. For comparison, here's my stamp for 1970 convertible...
Old Jan 29, 2008 | 01:19 PM
pwsusi's Avatar
pwsusi
Thanks Z Man. This was original picture was actually from '70 LT-1 coupe; not a '71. So the first digit alone (1) is a red flag...should start with "70" like yours. I passed on the car.
Old Jan 29, 2008 | 07:09 PM
mstanton's Avatar
mstanton
70 and 71 VIN engine codes were not the same. 70s were as depicted above, 70S4XXXXX. Early 71s used te same format, 71S1XXXXX. Most 71s were as follows, C11S1XXXXX. The upside down VIN should be a 72, 12S5XXXXX.
