Stripped hoses in dash material
Old Feb 10, 2008 | 09:20 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Stripped hoses in dash material
Hoses, should be holes...
How do you guy fix the holes in the dash pads of your 68 - 72. My center gauge panel is just loosely fitted with stripped out screws. Is there a quick fix?
Old Feb 10, 2008 | 09:48 PM
SLVRSHRK's Avatar
SLVRSHRK
Although I haven't tried it, you might try to epoxy some rubber behind the old holes and pre-drill it with a small pilot hole. That might get you the same kind of grip as the original dash material.
Old Feb 11, 2008 | 01:09 AM
7T1vette's Avatar
7T1vette
It sounds as if you do not have the little tapered washers that fit in those holes before the mating screws are installed. If you do not have them, you need to order some to make the dash pad right. For the rework, use some blue painter's tape to mask off the surface around each hole. Get some JB Weld [putty-type epoxy] and mix up a marble-sized ball of it. Pinch off a bit and put it in the hole entry areas (work on one at a time). Use one of the tapered washers and press it into the epoxy to shape it properly....you might want to put just a light wipe of oil on the surface of the washer so that it will pop out of the epoxy easily. Use a toothpick, paper clip, whatever to retrieve the washer. Do the same for the other holes. Let epoxy harden; drill hole for allowing the screws to pass through easily; clean the hole surfaces then use some vinly dye on a cotton swab to re-color the new hole surfaces. How's that?
Old Feb 11, 2008 | 01:16 AM
Theiskell's Avatar
Theiskell
it worked for me great
Old Feb 11, 2008 | 09:48 AM
Budman68's Avatar
Budman68
St. Jude Donor '07
Thanks, I'll pull the center gauges and look at the holes to see if they are repairable. Where can I buy those inserts?
Old Feb 11, 2008 | 02:15 PM
7T1vette's Avatar
7T1vette
Most of the Corvette aftermarket supply places...especially those that carry "hardware". My catalogs are in boxes right now [just moved], so I can't check them out. Try Corvette America, Mid-America, Ecklers, Rik's Corvette Parts; one of them should carry them. I don't think any of the local auto parts stores have them....they are a special design from GM and I've never seen them on anything else. Check your driver's side dash upper screws. If they are correct, take one out and check it out. If not, buy six (or 10, if you want any spares).
Old Feb 11, 2008 | 04:11 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Is this it?
Old Feb 11, 2008 | 04:16 PM
jimvette999's Avatar
jimvette999
Check this thread, post #6. Hope this helps ya.
Jim
http://forums.corvetteforum.com/show....php?t=1701027
Old Feb 12, 2008 | 12:07 AM
my72vette454's Avatar
my72vette454
I have used those plastic drywall anchors and just pushed them in the stripped out holes and they actually work pretty good, and the price is right too.
To Stripped hoses in dash material
