Replacing Door Ajar Switch
Old Feb 18, 2008 | 04:11 PM
Wig's Avatar
Wig
Default Replacing Door Ajar Switch
How do you get to this switch in order to repace it?
Old Feb 18, 2008 | 04:35 PM
OldToys's Avatar
OldToys
St. Jude Donor '09
Through the access panel in the rear fender well.
Old Feb 18, 2008 | 04:54 PM
7T1vette's Avatar
7T1vette
Actually, you only need to turn the hex-nut counter-clockwise till it comes loose. YOU NEED TO DISCONNECT THE BATTERY BEFORE WORKING ON IT. Also, with the wires still connected, you won't be able to pull it out very far. If you don't have enough slack to work on it, they you will have to pull the rear wheelwell cover plate.
You can purchase new replacements from www.lectriclimited.com or other Vette aftermarket parts places. Local auto parts stores will NOT have the correct switches. They will have similar switches, but minor differences will keep them from working properly.
Old Feb 18, 2008 | 09:18 PM
marines's Avatar
marines
Does one have to remove rear wheel to access this panel?
Old Feb 18, 2008 | 10:58 PM
Wig's Avatar
Wig
Thanks a lot. Just learned something new.
Old Feb 19, 2008 | 01:29 PM
GD70's Avatar
GD70
No, but it's tight in there. Removing the tire just makes it much easier to get in there and SEE what you're doing.
Old Feb 19, 2008 | 04:12 PM
Casper's Avatar
Casper
What wheel, left or right? My light comes on when I turn on the lights.
Old Feb 19, 2008 | 05:47 PM
Red70vette's Avatar
Red70vette
It all depends on which one is not working properly.
To Replacing Door Ajar Switch
