My 73 the fuel guage always says empty. I know gas is expensive but it ain't empty. I fill it to the top, still say's empty. Where do I look in the dash or pull the tank? I don't want to drop the tank If I don't have to.
You might be able to reach it from the top. It should be off to the right of the filler neck. You'll want to slide it off of the terminal, clean it and the terminals, and install it again.
See, a bad or no connection would leave you with a reading of an empty tank. If you ground that wire with the key in IGN, it should show a full tank.
Your sender wire may have a bad connection, and it might be fine. I would start back there though.
73 has the sending unit at the bottom of the tank. No need to drop the tank. You need to drop the spare tire and top cover. The sending unit is on the pass. side.
I had a bad wire this past December that was hard to fix.
My car had a new gauge and a new sending unit , but the gauge on my car actuall read way past full.
Had to use a test light and found current to the gauge and current comming out of the gauge. But when I checked the wire under the sill plate there was nothing. Turned out the wire had a cut in it behind the dash after it came out of the gauge. I ran a jumper wire and all is good.
So get a 12V test light and ground it to the frame at the tank. Then touch tip to the wire that plugs to the sending unit with switch on.
If the light does not come one the move to the gauge and see if current is going to the gauge / then out of gauge.
If the light does come at the sending unit test location then the sending unit may be the problem.
But you need to narrow down the possibilites before going forward
I climbed under the car. First let me say I just bought this car, so I don't know much about it. When I bought it I had it on a lift to check out the underside for rust and stuff like that, but wasn't anything that stuck out at me. Now back to the present, I removed the spare tire and related items. The gas tank is new, along with the hoses and it appears the sending unit has been replaced. That had me worried so I checked, and the car has not been wrecked. I called the original owner he said that the tank leaked, so he had it replaced. The fuel guage still says empty. With a voltmeter, should there be voltage at the sending unit between the post and the ground tab?
