Vacuum hose
Old Mar 17, 2008 | 01:50 PM
c3_dk's Avatar
c3_dk
Default Vacuum hose
Hi,
I am going to connect my vacuum hose from the HEI to my Rochester 7029207 carburetor.
I can see 2 connections on the Rochester, one in the front, and one on the passenger side
Witch connection shall I use?
/John
Old Mar 17, 2008 | 02:01 PM
halfmoontrail's Avatar
halfmoontrail
Typical for vacuum advance to use the nipple on the front bottom of th carburetor.
Steve
Old Mar 17, 2008 | 02:30 PM
c3_dk's Avatar
c3_dk
Steve
Thanks Steve
Old Mar 17, 2008 | 05:24 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
the outlet from the carb that you use should only be pulling vacuum when the car is under acceleration. Otherwise your timing is going to be off.
Old Mar 17, 2008 | 05:36 PM
7T1vette's Avatar
7T1vette
Test both outlets to see which has vacuum on it at idle. Choose the one that does have idle vacuum; plug off the other one. If both have vacuum at idle, take your pick.
To Vacuum hose
