Power Windows
Old Mar 25, 2008 | 09:42 PM
johnrem46's Avatar
johnrem46
Default Power Windows
I do not have power to my power windows!! When I connect the window to the battery they work. I checked all the fuses and they are good. I think I may have a bad power window relay does anyone know how to check the relay to see if it is good?
Old Mar 26, 2008 | 08:09 AM
BTAL's Avatar
BTAL
St. Jude Donor '09
I would check the switches first with a multi-meter. You'll probably find the problem there.
Old Mar 26, 2008 | 11:51 AM
7T1vette's Avatar
7T1vette
The relay should send 12vdc out to the window motors when you depress the switch. Turn car to "on" [don't start it], set up multimeter for DC volts, connect + lead to the output terminal of the relay (the input side should have 12vdc on it all the time), and have someone depress a window switch. If that doesn't show any voltage, the relay is bad. If it does show 12vdc on the relay output, the problem is in the window switches or the wiring to the motors.
Old Mar 26, 2008 | 11:52 AM
7T1vette's Avatar
7T1vette
I omitted that the (-) lead should be connected to a [known] good ground.
Old Mar 26, 2008 | 12:21 PM
'75's Avatar
'75
The power window relay should supply power to the window switches all the time the ign is on. From the switches the wires go directly to the window motors. There is a circuit breaker in the fuse box for the windows, it is in the top left just beneath the emergency flasher.
Old Mar 26, 2008 | 12:29 PM
7T1vette's Avatar
7T1vette
That is correct. But if the relay doesn't supply the 12vdc, the windows won't work.
Old Mar 26, 2008 | 12:53 PM
Sully1882's Avatar
Sully1882
Default im listening too
If one window works and the other doesn't can you just try changing the switches to see if the switch is bad...??? I'm guessing they are reversible...right?
Sully
Old Mar 26, 2008 | 04:43 PM
johnrem46's Avatar
johnrem46
Thanks to 7T1vette windows are now working .. Had a bad ground..
Thanks everyone. This is a great site!!
Old Mar 27, 2008 | 12:02 AM
7T1vette's Avatar
7T1vette
To Power Windows
