I agree it looks expertly done, but what's the purpose? Couldn't you just open the door or reach through the open window and pop the hood? Were you having problems with the factory hood catch and release system?
What happens when you try to take the hood off the car?
It looks good, what are the details on this project?
Actually that's a NASA type backup hood release in case the inside hood release cable breaks. That way he can still open the hood.
I recall a story about a guy at a Corvette show who pulled up and no sooner did something on or around his engine catch on fire. He saw the smoke, pulled the handle to pop the hood...and POP, the cable broke with the hood latched.
He had a fire extinguisher in hand ready to fight, but the hood was still latched. He had to wait and watch his chrome bumper plastic car burn.
Maybe had he been able to get the hood up and fight the fire, the damage would have been minimal instead of a total loss.
Yep. That is so that interested bystanders can pop the hood and check out the engine bay when you're in getting a haircut.
That part of the car is hard to see even if you're looking for it. I doubt someone will randomly 'stumble' on it's existence let alone assume what it's for. I would be more worried about the rattling that metal ring might produce vibrating on that panel...more than I would someone getting under the hood.
The metal ring is there as an after thought. I bought a choke kit from local parts store but it was too short. I could (should) have taken it back and exchanged it for one designed for a truck (9') but I found a longer piece laying around in my junk yard looking garage and used it instead....wasn't sure it would work anyway. First tried to attach to body mounted latch (where inside cable attaches) and run pull wires down into wheel well but couldn't get it to pull open hood. Even tried going thru the rubber gromet near the latch into the wiper well and reaching under lip of hood to pull it open but thad didn't work either. I'll probably replace at least the ring or entire cable now that I know it works, but if not, the only thing that will probably see it is my cat if he goes under there for a nap. If I caught someone down there looking around it wouldn't be my cat that attacked him.
I fooled around the same way you did with the wheel well, wiper valley and such. I ended up using a somewhat thick electrical wire routed thru some round grommets down to a "secret location". So if the stock hood release does break (its old) then I have a backup. The key here is to put it somewhere someone won't just stumble upon it. I think ya did a good job. Noone would think thats a hood release latch if they found it anyway. You could always disguise the pull ring. Maybe use a bolt and make it a "T" handle that looks like a bubba f'up but its functional.
It looks like a good design- and one good alternative. Another choice would be to replace the hood release cable with a new one, if the current one looks original or weak. A replacement cable is cheap insurance and will probably last another 20-30 years with a little occasional lubrication of the latch mechanism. I had to do mine last week- and regret not anticipating this common C3 problem earlier.
Good idea....I like your thinking! I have been putting off making a plan for a backup hood release. Now I can just get to work, thanks for sharing.
Having just dealt with a broken hood release and experiencing lots of angst, misery, barked knuckles, and aggravation trying to get the hood open, I made almost exactly the same modification so the hood can be released in an emergency.
Scoff if you will, but its a great idea, and as far as stealing the car, in my opinion, no living person except a Corvette owner would ever look for a hidden hood release, and a "real" Corvette owner would not steal another man's car.
Er ah............... unless you live in Southern California.
LOL
Nice job man.
Skip in Houston
