fiberglass work
Ok,, here is their secret home cure,, Duct Tape
I am sure you could sell tickets to this cure but I guess if you put it on and peel it off the tape acutally pulls the glass fibers out and relieves the itch. Might want to try it on a test area, mind you they do this on their arms not their heads. Would make an interesting video
Good Luck
Bill in RI
Yes, duct tape will remove the fibers that you do not see. I have used this many times around vettes and aircraft.
I also found showering in cool/cold water helps, then apply and remove duct tape.
