Surgery sucessful
Old Apr 25, 2008 | 11:23 PM
rihwoods's Avatar
rihwoods
Default Surgery sucessful
Broke an alternator bolt off in cylinder head on the 69 502 and finally got around to extracting broken piece today at my friends shop..had to use an angle drill to drill hole for easy out...to my suprise,after broken piece out,discovered ANOTHER piece deeper in...extracted that and figure that PO left broken piece in and installed a "shorter bolt"...as both pieces were definately "ends" of different bolts...
First piece....you can just make out "taper" at end of threads..
Bolt broke off here...
2nd piece from deeper inside....
What was a real trick was using an angle air drill to drill broken bolt for easy out due to space constraints...discovered second piece using a small mirror/light....glad I thought of doing that or new bolt would not have gone in deep enough...
Old Apr 25, 2008 | 11:30 PM
onaqwst's Avatar
onaqwst
i never had luck with extractors....
soo..... did you use a cadaver?
b
Old Apr 25, 2008 | 11:59 PM
rihwoods's Avatar
rihwoods
b
How ya doin...???
Rich
Old Apr 26, 2008 | 12:43 AM
onaqwst's Avatar
onaqwst
i'm still trying to figure out my life...hyahaha.....
between trying to stay creative and being able to eat and then keeping others ideas going...grrrr....
i broke an extractor before and i think that cursed me for the rest of my extracting days ......... could have been that cheap set that i bought though
b
Old Apr 26, 2008 | 01:34 AM
gleninsandiego's Avatar
gleninsandiego
I had the privilege of seeing Rich's car in person today. It is great!i
Glenn
Old Apr 26, 2008 | 08:05 AM
rihwoods's Avatar
rihwoods
b
I did not do it myself...my friend Kenny is very good at extracting broken bolts...we were joking about switching heads around in case we messed up though...(they are drilled same at each end)...
Old Apr 26, 2008 | 08:10 AM
rihwoods's Avatar
rihwoods
Pic showing new grade 8 bolts to cyl head......thinking now about using locking tab on bracket bolt to cyl head...but definately will be checking tightness frequently from now on...
Old Apr 26, 2008 | 08:17 AM
rihwoods's Avatar
rihwoods
Glenn
Thanks Glenn....from recent pics of your project,it was neat to see your wife pitching in removing the old paint...
To Surgery sucessful
