1974 paint codes
Old Apr 28, 2008 | 08:56 PM
emccomas's Avatar
emccomas
Default 1974 paint codes
Would all who have a 1974 Corvette check your paint codes for me. Many references list the 1974 paint codes in the form 9xx (where xx is a two digit number representing a color).
However, every 1974 that I have looked at (hundreds over the years) has a paint code in the form xxL (where xx is again a two digit number representing a color).
Just want to confirm that no one has a 1974 Corvette with a paint code of the form 9xx.
Thanks.
Old Apr 28, 2008 | 09:02 PM
dannyman's Avatar
dannyman
9xx
See following link:
http://www.100megsfree4.com/corvette/1970/vet74.htm
Dan
Old Apr 28, 2008 | 10:00 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Ed, I at one time had listed and viewed over 300+ 1974 Corvette trim tags from a first day production car to a car 10 VIN #s from the "last" '74 built. I never saw one, nada, 9XX for a paint code. Every one was an "80L", "56L", "10L", "22L" and so on.
Old Apr 28, 2008 | 10:49 PM
RMS73's Avatar
RMS73
For '74 VIN 36 the paint code is 10L. That is the earliest I have seen.
Roger
Old Apr 29, 2008 | 12:26 AM
Todd M's Avatar
Todd M
I believe I have #7788 built in November 73. It has a paint code of 74L.
Old Apr 29, 2008 | 03:11 AM
ROBRICCI's Avatar
ROBRICCI
# 8167 here, built Nov. 5th, 1973, code 74L.....
its my understanding that the "L" stood for "lacquer" ......
Old Apr 29, 2008 | 06:03 AM
emccomas's Avatar
emccomas
I believe that the L stands for "Lower". 1974 was when Chevrolet offered two tone paint schemes on many of its models. The two tone paint codes would be something like xxU yyL, where U was the upper color paint code, and L was the lower color paint code. Vehicles that had a single color had one paint code, of the form xxL.
Old Apr 29, 2008 | 06:05 AM
emccomas's Avatar
emccomas
Originally Posted by dannyman
Yep, that comes from Chevrolet documentation. But no one has ever seen an actual 1974 Corvette with a paint code of the form 9xx. I believe that a change was made after the documentation was prepared.
There has to be a record of an Engineering Change Order somewhere.
Old Apr 29, 2008 | 06:07 AM
emccomas's Avatar
emccomas
That has been my experience as well. I have looked at hundreds of these over the years, all of the form xxL.
Old Apr 29, 2008 | 11:02 AM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Roger
You are correct Sir....and here it is.....# 00036.
Old Apr 29, 2008 | 04:29 PM
rkingce's Avatar
rkingce
So does that mean if you have a 1974 with a 10L you have a White Car or should have one?
Old Apr 29, 2008 | 04:30 PM
dannyman's Avatar
dannyman
Are you telling me that we can't trust the Generals documentation.
Sorry misread your question. :o
Old Apr 29, 2008 | 04:48 PM
rkingce's Avatar
rkingce
Im I correct, a 10L would be a white car. I have #1545 and its code is 10L but its Red...........
Old Apr 29, 2008 | 06:38 PM
RMS73's Avatar
RMS73
10L = white from the factory
76L would be red from the factory I believe since 976 was red in 1973
Roger
Old May 7, 2008 | 09:12 PM
RMS73's Avatar
RMS73
Found a picture of the window sticker for VIN 22115. It shows 10L Classic White for the color.
Roger
Old May 8, 2008 | 11:05 AM
dmaaero's Avatar
dmaaero
56L = bright yellow
Old May 8, 2008 | 09:00 PM
Mike-C3-73's Avatar
Mike-C3-73
1st Gear
I recently purchased a '73 (I fairly sure from the original owner). It came with the original window sticker. On the list of "options & accessories" is (the last two):
422 Dark Saddle Custom Interior
945 45-45 DARK BLUE-GREEN MET
I haven't located the plate on the vehicle yet. Is that the 3 digit code you're talking about??
I am a new owner, new to the forum as well... trying to assist...
To 1974 paint codes
Old May 9, 2008 | 07:08 AM
emccomas's Avatar
emccomas
Yes, but this discussion only applies to 1974 model year cars. 1973 cars definitely used the 9xx format for the paint code.
The issue is that Chevrolet documentation for the 1974 model years indicates that the paint codes format is 9xx (like 1973). However, no 1974 Corvette has ever surfaced with a paint code format of 9xx. They all (so far as we can tell) have a format of xxL.
Old May 12, 2008 | 03:52 PM
outlawkinser's Avatar
outlawkinser
#437138 14L Silver Mist
Old May 13, 2008 | 06:25 AM
aussiejohn's Avatar
aussiejohn
Default Confusing
G'day,
My '74 coupe was dark brown metallic and has the code 68L on the TRIM PLATE. Now, according to my copy of the Cars and Parts Magazine's "Catalog of Corvette ID Numbers 1955-93" the 1973 and 1974 cars had a 9xx code and 910 is Classic White while 968 is Dark Brown Metallic.
However, the Trim Plate on my car has on the top line, CHEVROLET J03,
second line 416 68L.
The J03 means May 03 (1974) build date.
The 416 means Medium Saddle Leather (trim colour and material), and
the 68L presumably means the body colour, which in my case is Dark Brown Metallic. You can see the similarity between "968" and "68L".
The book goes on to say that for the 1975 model year, Classic White is code 10, a two digit number. All the other paint codes are two digit numbers. As for the Trim Numbers, the LEATHER trim has a THREE digit NUMBER, while all the VINYL trimmed cars have a TWO digit number followed by the letter "V".
As there is not a panoply of various year Corvettes around me to research, I can't tell you what TRIM PLATES on a '75 say, but someone will chime in.
Regardsm from Down Under
aussiejohn
15 months to go
