Oxidized Paint
My 1980 corvette's paint is pretty badly oxidized. Other than this, the paint is in pretty good shape for a driver.
Now, I wan't to bring the paint back to life. I was told to use the following;
1. 3M Perfect It II - rubbing compound
2. Meguiar's Mirror Glaze (Machine Glaze)
3. Mother's Pure Carnauba Paste wax
and.... to apply the above in this order by hand.
Please offer me your opinions.
Thank you in advance.
I like the 3M Finesse-It II using a power buffer with a good wool pad.
You can do it by hand, but it's a lot of work that way.
If you haven't used a power buffer on a car before, get someone to show you how. You can burn right through the paint if you don't know what you are doing.
Minor surface oxidation can be removed by polishing with a mild polish such as Menzerna Final Polish, Meguiar's No.9 Swirl Remover or 3M Swirl Remover. After polishing, finish with your favorite wax or paint sealant. Severely oxidized, neglected or abused finishes require a 3-step, compound, polish and finish restoration process. These are the same three steps used by body shops and professional detailers
Compounding abrades away the top layer of dull, oxidized paint and in the process, removes swirls, scratches and minor paint blemishes. Compounding is typically accomplished using an Orange Power Pad or, for maximum cut, a Yellow Compounding Pad. Compounding may leave a surface haze. This is normal. This dullness, or compounding haze, is removed in the next step which is polishing.
Polishing removes compounding haze and restores surface gloss. It creates a mirror-like, highly reflective finish ready for waxing. Polishing is best accomplished using a white foam polishing pad and a finishing polish.
Finishing protects the surface with your favorite wax or sealant. Finishing can be accomplished by hand or with an orbital polisher. Applying a wax or paint sealant by machine is typically done using a black foam finishing pad.
Good Luck!
Now what I'm about to suggest you are probably going to cringe.
A close friend told me about doing this to both his 62 and his 70 LT-1.
The paint on both cars was chalky like mine when he first bought
them.
In stages, one fender at a time, then a door, hood and so on,
take a clean tee shirt, spray WD-40 on the surface and rub -
(not super hard) but enough to work into the surface.
Then, using another tee shirt, buff it off. No paint came off!
Amazing results. Yes, it took what wax was left on the car off and
the chalky haze was gone. Then, applied the Meguire's paint cleaner,
polish and wax to her. Unbelievable appearance.
Take it for what it's worth.
It worked for us and I'm sure it will work for you as well.
Rudy
them.
Rudy
