refelxtix question
Old May 13, 2008 | 08:32 AM
76greybeard's Avatar
76greybeard
Default refelxtix question
I am planning to put reflextix in under new carpet but am wondering if it should be glued in place and if so, with what? Thanks in advance for any help
Old May 13, 2008 | 08:37 AM
jgrigg's Avatar
jgrigg
I used 3M spray adhesive to glue down my Reflectix, worked great for me with no mess.
Good luck
Old May 13, 2008 | 08:55 AM
ridikulus's Avatar
ridikulus
Good luck
Same here. 3M spray worked perfectly and the reflectix went down surprisingly easy.
Old May 13, 2008 | 09:20 AM
nw2571's Avatar
nw2571
Another happy customer of Reflectix and 3M spray adhesive. I used two layers in the normal problem areas; along trans tunnel, floors in front of seats, and inside firewall. Most on here have done the same according to my research.
Also if you haven't done much research yet on this subject, use the high quality aluminum tape to seal all joints, don't use cheapo duct tape. The other common issue people have is the need to adjust the throttle cable to handle the thickness change under the carpet. For this reason, I put one layer only directly under the accelerator pedal.
Old May 13, 2008 | 09:35 AM
Maymyvetteliveforevr's Avatar
I did the exact same procedure with both products and it worked out great, I think the 3M in Canada was around $13.00 or so for a can.
Old May 13, 2008 | 10:03 AM
70Yellowbird's Avatar
70Yellowbird
I was wondering if the additional thickness along the trans tunnel caused fit problems with the shifter console, especially if you doubled it. How was your re-install done in that area?
Thanks.
Old May 13, 2008 | 11:21 AM
7T1vette's Avatar
7T1vette
3M spray adhesive...one layer thick...put Reflectix on every possible surface under the tunnel console and up the inside of the firewall as much as possible. I covered the vertical panel behind the seats, but did not do the storage compartment [too thick to do the doors]. I had no heat problems after the work. No glue on carpet except for vertical panels and aluminum-foil tape on all of the Reflectix joints. It will make an incredible difference in summer driving comfort.
Old May 13, 2008 | 12:35 PM
76greybeard
Thanks guy's, as always it is good to talk to someone who has already done something
Old May 13, 2008 | 12:50 PM
tfi racing's Avatar
tfi racing
A little glue and the silver tape that goes with it is all I used and it still seems to be holding up fine.
Old May 13, 2008 | 02:33 PM
WillEE's Avatar
WillEE
I just did this during the last week to my car and found that the 2' x 25' roll at Lowes ($25) was enough to do the entire car including the insides off door panels and even have a little left over. This was done in conjunction with a new carpet kit and I used almost 3 cans of 3M adhesive in the process of it all. It really helps to change razor blades often - esp. on the carpet detail work/trimming where a clean edge will show.
To refelxtix question
