T-Top skin/shell
Old May 17, 2008 | 06:18 PM
KENS80V's Avatar
KENS80V
Default T-Top skin/shell
Is it possible to replace a cracked fiberglass t-top skin/shell. I saw a post on here some time ago of a guy bonding a new shell on to a t-top frame. I recently acquired a used pair cheaply but instead of trying to fix a large crack in one of the tops I thought it might be easier to remove and bond on a new one. Where can they be purchased?
Old May 17, 2008 | 07:24 PM
Ron R's Avatar
Ron R
Pretty sure it would be a lot easier to just fix a crack.
Old May 17, 2008 | 08:30 PM
Alan 71's Avatar
Alan 71
I think Ron is right. Since you can get to both sides of the shell to do the repair that's probably the best and easiest way to go.
Regards,
Alan
Old May 17, 2008 | 11:47 PM
VetteThunder1's Avatar
VetteThunder1
Having unbonded old fiberglas, I have to say, go and fix the crack, its a lot easier.
Once you unbond the fiberglas it tends to warp some so when it comes time to fit things back together its a PITA.
just my $0.02.
To T-Top skin/shell
