Where to mount inline fuel filter??
Old May 19, 2008 | 07:11 PM
MakoShark72's Avatar
MakoShark72
Default Where to mount inline fuel filter??
I was thinking about putting a filter inline just prior to the carb, but then was thinking that I wanted to keep fuel fittings to a minimum in the engine bay...and also to keep a cleaner look....NOW thinking about rear near the tank.
Thoughts, or other options??
Thanks.
Old May 19, 2008 | 08:12 PM
tnovot's Avatar
tnovot
If you do a search, I think you will find that most guys recommend a filter as close to the carb as possible. That would be downstream of the fuel pump which does a good job of providing pressure but not good at pumping with restricted suction.
If it's a trade off between function and looks, you have to make that decision.
Terry
Old May 19, 2008 | 10:10 PM
eastltd's Avatar
eastltd
How about something like this?
You can buy them through Summit with the AN fitting and tie it into your tee fitting.
Old May 19, 2008 | 10:53 PM
MakoShark72
Like it...Thanks!
Old May 19, 2008 | 11:12 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
I got this from Summit Racing and installed it (with inline filter) this weekend....
Old May 20, 2008 | 10:18 AM
terrible_buddhist's Avatar
terrible_buddhist
I have been really considering this!
I have been getting 'hickups' while cruising, I realized I have no fuel filter after the fuel pump...wondering if thats whats causing it.
Old May 20, 2008 | 11:48 AM
PETKAH's Avatar
PETKAH
On my '70 I have a fuel filter about 2-3 feet from gas tank near frame rail - never developed any problems.
Old May 20, 2008 | 12:49 PM
pbcanney's Avatar
pbcanney
when you install it on a holley, wouldn't the gauge be on the bottom?
Old May 20, 2008 | 12:57 PM
MakoShark72
It would as a matter of fact...unless they sell "right" and "left" hand versions...
Good observation..
Old May 20, 2008 | 04:31 PM
427basketcase's Avatar
427basketcase
I built this one, follwing the paper here that Lars published. The only difference is the filter part # You also want to make sure the filter is as vertical as possible to prevent vapor lock.
Old May 20, 2008 | 05:25 PM
lars's Avatar
lars
On a street car with a mechancal engine-mounted pump, put the filter between the pump and the carb. Here's another photo of a setup like this:
Old May 20, 2008 | 08:39 PM
vetteguy75's Avatar
vetteguy75
There's a plug on the other side...you just swap the gauge with the plug....
Also, I used my existing Holley pressure gauge.
Old May 20, 2008 | 09:19 PM
c3corvette77's Avatar
c3corvette77
i'm running a filter in the fuel line under the car just where the seam on the front of the passenger door is. seems to work ok. i'm considering the summit fuel rail as well.
as for the hiccup while cruising, run the voltmeter tests on your coil, if you have HEI. i had a hiccup while cruising after about 30 minutes. thought it was vapor lock, turned out to be a bad coil.
Old May 21, 2008 | 12:57 AM
eastltd's Avatar
eastltd
That looks nice Lars. Where did you get the line dividers?
Old May 21, 2008 | 09:40 AM
terrible_buddhist
I am still running points
Old May 21, 2008 | 12:43 PM
toddalin's Avatar
toddalin
Another way to do it. Many would say don't use a glass filter housing though.
Old May 21, 2008 | 02:07 PM
lars's Avatar
lars
Summit has a pretty good selection of the clamps.
Lars
To Where to mount inline fuel filter??
Old May 24, 2008 | 01:00 PM
jshug's Avatar
jshug
My stock 1971 holley has small brass/bronze filters at the fuel input fitting on the carb.
Old May 24, 2008 | 01:28 PM
MakoShark72
So does mine, it turns out..
Old May 24, 2008 | 04:35 PM
toddalin's Avatar
toddalin
Holley/Chevy performance manual says to get rid of them and replace them with an in-line filter. They tend to clog and restrict flow.
