How to repair clock?
Old May 28, 2008 | 10:02 PM
gccch's Avatar
gccch
Default How to repair clock?
Let me start out by saying I do not want a quartz replacement. I just want to repair my clock without breaking it... How do I get the hands of the clock off so the face can come off? I'm going to try lubing it up so it keeps on ticking.
Old May 28, 2008 | 10:07 PM
David 1972 vette's Avatar
David 1972 vette
8th Gear
Hi, I fixed my clock and didnt have to remove the hands. I took it out of the dash and with a small pair of pliers opened up the two or three tabs that hold the back onto the face. I then took to back off, lubed the gears and lightly filed the points and away it went again. Hope this helps. Cheers Dave
Old May 28, 2008 | 10:13 PM
stock76's Avatar
stock76
This should help you: http://www.corvettefever.com/howto/24699/index.html. Here is another really goo link with pictures: http://www.pcfred.com/Vettetip/FixC3Clock.htm
Old May 28, 2008 | 10:14 PM
gccch's Avatar
gccch
I'm glad I dodn't follow my first instinct... that would have left me with a broken clock.
What did you use for lubricant?
Thanks,
Old May 28, 2008 | 10:15 PM
gccch's Avatar
gccch
Originally Posted by stock76
That's the ticket! Thanks!!
Old May 28, 2008 | 10:19 PM
jrl77's Avatar
jrl77
Thank You !
I was A little ticked off by the $'s it would cost to replace / rebuild mine. I'll let you know how it turns out.
JRL
Old May 28, 2008 | 10:25 PM
stock76's Avatar
stock76
Take a look at ther other link I added to my original reply above. I think it is even better, though both are good. Best of luck with it.
Old May 28, 2008 | 11:15 PM
David 1972 vette
8th Gear
I just used WD40 to lube mine. Probably not the best thing to use but it worked
Old May 28, 2008 | 11:29 PM
7T1vette's Avatar
7T1vette
Use watch oil and only on pivots (never on gears). Also, check the condition of the contacts for the rewind system; they are notorious for cracking and breaking off. Also, be very careful of the balance wheel and spring...it doesn't take much force to damage one beyond repair.
ZIP Products sells a repair kit for the original electro-mechanical clock; it is essentially an entire duplicate mechanism with instructions on how to repair it. You need to tell them the number of teeth on a particular gear to get the correct repair kit. I rebuilt mine about 2 years ago and haven't had any trouble with it since.
Old May 29, 2008 | 01:36 AM
Chris Farrer's Avatar
Chris Farrer
I bought a fully restored original clock from Redline Clock and Gauge repair (John ???),for under $100. Works perfect.
Old May 29, 2008 | 10:09 AM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
DO NOT USE ANY OIL. you dont see a watch repair man use any OIL
take it to A watch Guy he has blow on power for your clock .I just took mine to my watch guy he said see all this burning black kinda stuff its where some one used oil .it will burn the coil up Possibly.
He told me he could have made that clock work for ever but it shorted out and it burnt the wire going to the coil.DO USe Any Reg OIL. it will cost you in the end. Voice of sperence!!!!!!
Old May 29, 2008 | 12:05 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Cleaned mine gently; added a film coat of WD-40; ran a separate ground from the case to beneath the console. It has run like a champ ever since.
Old May 29, 2008 | 12:17 PM
Wuttin's Avatar
Wuttin
Originally Posted by Lon Wayne
DO NOT USE ANY OIL.
I agree...I fixed the clock on my 79 by filing the points and using some TV tuner contact cleaner to gently strip all of the gunk off of the works. Oil will only make it worse, in a fairly short time frame. If I remember I finished off with a very light blast of spray silicone, just to exclude moisture and keep it happy. Two years and running well.
Old May 29, 2008 | 12:27 PM
gccch's Avatar
gccch
Thanks for all the tips. I've got it back in and running a few hours now. Seems to be all set. Now on to the radio.
Old May 30, 2008 | 11:04 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
You could do a search too.
http://forums.corvetteforum.com/show...ighlight=clock
Old May 30, 2008 | 11:20 AM
Evmcevil's Avatar
Evmcevil
Two replacement inserts 1 OEM New Old Stock replacement and $550 later, I still don't have a working clock!!
Old May 30, 2008 | 04:36 PM
Chris Farrer
Contes have a 72-74 NOS clock for sale at $125.
To How to repair clock?
