Exhausted
Old Jul 3, 2008 | 08:29 PM
vett us all's Avatar
vett us all
Default Exhausted
SB C3 ANGLE PLUG HEAD OWNERS FORGET ABOUT GETTING HOOKER SIDE EXIT HEADERS. OR ANY OTHER MAKERS OF THE C3 SIDE PIPE HEADERS. THEY SIMPLEY DO NOT EXIST IN THEIR INVENTORY ON A POSITIVE NOTE SUPPORT OUR TROOPS AND HAPPY BIRTHDAY AMERICA
Old Jul 3, 2008 | 08:54 PM
Billysvette's Avatar
Billysvette
They have short spark plugs for that problem
Old Jul 3, 2008 | 10:04 PM
'71VetteRacer's Avatar
'71VetteRacer
For Edelbrock performer RPM heads with angled...even short header plugs will not allow enough clearance. Don't ask me how I know! makes you leave one helluva dent in one of the tubes!
Old Jul 5, 2008 | 06:48 AM
Thmprr's Avatar
Thmprr
It's bad design by Hookers to not allow for angle plugs. What were they thinking!
Old Jul 5, 2008 | 10:52 AM
Billysvette
I have edelbrock angle plug heads,victor jr,and i have hooker super comp headers ,not side pipe.and i got short plugs and i have plenty of space,what is your problem with your headers.Just wondering what you guys problem is.There must be some kind of difference between the straight headers and the side pipe headers.
Old Jul 5, 2008 | 11:09 AM
'71VetteRacer
well, is yours a BB or SB? mine is a SB, and there was no way that the sidepipe headers would work without a dent!
Old Jul 5, 2008 | 11:39 AM
Billysvette
I have a small block,same as yours,what is the problem that you have?
Old Jul 5, 2008 | 12:07 PM
'71VetteRacer
with the side pipes, the headers don't clear the #4 cylinder.....maybe it's just me? are your heads performer or performer RPM?
Old Jul 5, 2008 | 07:20 PM
Billysvette
My heads are the victor jr series,i had plenty of room when i tested the fit,now you have me second guessing myself,i will check again.
Old Jul 5, 2008 | 07:29 PM
onaqwst's Avatar
onaqwst
pics pics pics
Old Jul 5, 2008 | 08:15 PM
'71VetteRacer
okay... here's a pic.
Yeah, I had decided to get the matched performer RPM setup (intake heads and cam)
Old Jul 5, 2008 | 08:37 PM
onaqwst's Avatar
onaqwst
check out that dual zip tie technique
Old Jul 5, 2008 | 08:42 PM
'71VetteRacer
actually, I saw a guys do that with a Trans-Am mustang. Works really well, holds everyting in place and out of the way. Kinda cheap, but I think it looks more Racey than a plastic holder that bolts to the valve covers....Also, it gives better acces to them from above, rather than feeding them under the headers
Old Jul 13, 2008 | 07:51 PM
Billysvette
Whats going in with all you guys,did you figure out a solution to the spark plug problem,i rechecked mine,put the headers on my engine on the stand and you are right # 6 plug wont work.Whats our solution,and what headers would work on our type heads? Bill
Old Jul 13, 2008 | 08:18 PM
'71VetteRacer
well, I have had Headmans on before I went to sidepipes and they worked. But if you want sidepipes, STAHL would be your best bet. They custom make them, but cost a good bit more!
Old Jul 14, 2008 | 10:22 AM
Billysvette
What size tubes did the hedmans have?I think i will just have to dent the tube like you did.
Old Jul 14, 2008 | 11:01 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
To Exhausted
Old Jul 14, 2008 | 11:44 AM
Billysvette
Originally Posted by yellow 72
What heads are you running and its the passenger side #6 plug thats in the way on mine.
Old Jul 14, 2008 | 12:31 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Trick Flow G1 twisted wedge...here's #6
Old Jul 14, 2008 | 05:45 PM
Billysvette
Yellow72 you have trick flow heads,they are different then edelbrock heads,edelbrock changed their angle heads and they do not make a header that fits our cars (corvette).You have to get custom headers made,which really pisses me off because they dont tell you this in any advertisement.I called edelbrock and talked to their rep, and he told me i could only go to kooks or lemons to have custom headers made(kiss my ***) im pissed at the guy and tell him i have alot of guys on the corvette club ,that are having the same problem and he tells me they cant be concerned with them. oh im stoked now of the lack of regard for this problem.So i recomend that everybody dont buy their heads.Just a heads up. Bill
