clean a bare block
Old Jul 8, 2008 | 08:27 PM
dodge_ss/t's Avatar
dodge_ss/t
Default clean a bare block
ok i have a 427 and a 350 blocks that needs some work, i have no intentions of using them in the next 2 years but sincethere bare blocks i would like to clean them up (dirt, oil and grime) that's on the outside and paint them and store it in my spare room. it has to be clean and look good so i don't get an ear full so what's the best way to clean it up? sandblast? pressure washer and wd 40? dont want to spend a lot of $ on blocks i have no use for right now
Old Jul 8, 2008 | 09:20 PM
J.T.vette's Avatar
J.T.vette
Go to autozone and get some engine degreaser, and pressure wash them.I would not use wd40, it will attrack dust.
Old Jul 8, 2008 | 09:50 PM
1985 Corvette's Avatar
1985 Corvette
How would WD40 attract rust? I've read it's good to spray on the block while the block is still wet before flash rust occurs.
Old Jul 8, 2008 | 09:55 PM
hwcoop's Avatar
hwcoop
I would use engine degreaser, pressure wash, use compressed air and blow out all the oil galleries, bolt holes etc, wipe the cylinders and machined surfaces with oil(after you painted the outside of the block)
Then wrap it up in plastic to keep dirt and moisture out.
Old Jul 8, 2008 | 10:11 PM
dodge_ss/t's Avatar
dodge_ss/t
ive also read that. maybe if it dose atract rust then wd40 it and compliment it with a wipe down of oil?
Old Jul 8, 2008 | 10:19 PM
ctk30's Avatar
ctk30
I sprayed my extra block with wd40 and it's fine
Old Jul 8, 2008 | 10:31 PM
Theiskell's Avatar
Theiskell
He said "DUST" not rust
Old Jul 8, 2008 | 10:37 PM
dodge_ss/t's Avatar
dodge_ss/t
:o
Old Jul 8, 2008 | 10:42 PM
Theiskell's Avatar
Theiskell
I have used cosmeline (SP?) from a spray can that works great. When I lived in Florida I had a deep-sea boat and used it to keep my tools from rusting. They held up well out in the salt water you would have no problems with a block using that. I’m at work at the moment so I can’t give you the brand name, but when I get home I can take a look at the can for you.
Old Jul 8, 2008 | 10:51 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
I actually just got some degreaser, hosed it down and blow dried it with some compressed air, then applied some PB blaster to a wad of paper towels and whiped it down.
Old Jul 8, 2008 | 11:18 PM
randommj's Avatar
randommj
you should out 8 speakers and 1 square sub in the 427, thats wut I would do!
Miles
Old Jul 8, 2008 | 11:41 PM
dodge_ss/t's Avatar
dodge_ss/t
thanks
Old Jul 9, 2008 | 10:55 AM
Theiskell's Avatar
Theiskell
Here is a link, This stuff is great.
http://www.boatersworld.com/product/...3Bcilubricants
Old Jul 9, 2008 | 11:15 AM
ghoastrider1's Avatar
ghoastrider1
just a note..easy off oven cleaner works well also to get rid of grease.
Old Jul 9, 2008 | 12:55 PM
68/70Vette's Avatar
68/70Vette
You can buy engine storage bags (Eastwood, Morosco?). Why not just store them in their dirty state in a bag. They shouldn't be that noticeable. Out of sight, out of mind.
I note you didn't want to spend much money, but depending on how much you want to spend, hot tanking them is an option also.
But no matter what you do, I think getting an engine storage bag is the way to go. They are cheap and they will keep dust from accumulating.
Old Jul 9, 2008 | 01:26 PM
TimAT's Avatar
TimAT
If you bag them and seal them up really well, moisture will condense inside the bag from temperature changes. Add a couple big bags of silica gel or put together a cotton bag of charcoal to draw the moisture.
Old Jul 9, 2008 | 03:30 PM
7T1vette's Avatar
7T1vette
Use the pressure washer and some good detergent to clean them up. Then dry them well and give them a light wipe or spray coating of light oil (not motor oil...something like 3 in 1 oil or sewing machine oil). WD-40 is a "water dispersant" [hence the WD], not an oil; it can't provide long term protection. Then bag them to keep dust, etc. out. I would not recommend any shot blasting, as the shot can get stuck in oil passages, etc.
To clean a bare block
