door sills
Old Jul 9, 2008 | 10:09 AM
vettekid333's Avatar
vettekid333
2024 C3 of the Year Finalist - Unmodified
Default door sills
My door sills have become scratched over the years. Has anyone tried to take steel wool or sandpaper to these to clean them up? What is the best wat to do this, or should I just buy new ones. These are the originals.
Old Jul 9, 2008 | 10:21 AM
LYLE's Avatar
LYLE
They scratch and dent easy and I know of no repair but new ones. If you want them to stay new just use them for shows or cover them up cause by next year they will look bad again.
Old Jul 9, 2008 | 11:09 AM
BigEarl's Avatar
BigEarl
Mine were scratched. I sanded/primed/painted/cleared mine and they are holding up.
Old Jul 9, 2008 | 03:40 PM
7T1vette's Avatar
7T1vette
Similar to the silver rocker panels, the door sills are anodized aluminum. The anodized coating is harder than the aluminum sills and the coating is very thin. If you sand or do much polishing, you will wear through the anodized coating and the surface will never be the same. You can try buffing with a fairly fine rouge to see if the scratches will come out, but not likely if they are very deep. Replacement is probably your best bet. The standard sills are readily available and not very expensive.
Old Jul 9, 2008 | 04:28 PM
PETKAH's Avatar
PETKAH
You can also get an insert that fits over the original sills which have pre drilled holes the same as the original. I have one on my '70 which has the corvette letters spelled out. Many vendors have.
PS - if you are handy you could make some yourself - review the catalogs for pixs.
To door sills
