Tire selection
Old Aug 4, 2008 | 12:06 AM
70454Convert's Avatar
70454Convert
Default Tire selection
I need input on which tires to put on my 70 convertible. I bought it with circa 1975 "telestar" F70- 15 white walls which have good tread but are obviously not streetable. Its a white convertible and the F 70's tires look kind of wimpy. I'm thinking 255/60 15 on the original rallies for a more agressive/ wider look but am worried about the fronts rubbbing. B.F. goodrich has a 245/60 15. Then theres the 225/70. I'm definitely going with raised white letters.
It would help me make my decision if those of you with rallys could post pics of your car and tell me what size tire you're running. Anybody go with 225-70 front and 255-60 rear?
Thanks for your input.
Jordan
Old Aug 4, 2008 | 01:57 AM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
I have 245-60-15 all around and no rubbing
(now on Rally wheels)
Old Aug 4, 2008 | 09:27 AM
Roughrider's Avatar
Roughrider
Both sizes you've mentioned will fit the 15"x8" wheels with no problem. The potential problem is whether the tires (P255/60 in particular) will clear the body.
P255/60R15 became a factory optional tire beginning for the 1978 model year. That was after changes were made to the inner body panels for clearance. Prior to that, it's a car by car thing. Many have used the P255/60 tires and have had no problems at all...many have reported clearance problems.
My own theory is it depended on who was Chevrolet's vendor for fiberglass body panels at any particular time. The panels had to meet certain specifications for dimensions with some unavoidable plus and minus variations. Until Chevrolet changed the specs for inner clearance for 1978 and later, that variation allowed bigger tires for some cars and not for others. At least...that's my theory.
Old Aug 4, 2008 | 09:54 PM
Greg G's Avatar
Greg G
I hav 255 60 all aroung when I got the car and they rubbed on tight turns. When I purchased new tires I went with 255 60 rar and 235 60 front. Looks nice and no rubbing problem.
Old Aug 5, 2008 | 12:03 AM
70454Convert
Thanks for the replies. I'm leaning towards BF Goodrich 245/60 15's to minimize rubbing. I had the 255/235 combo on my 77 with the stock aluminum wheels but the 235 didn't fill out the wheel well. Tire rack has a good price on the BFG's.
Posts on the NCRS site vary as to 255's on the front of a 70. The big block sits a little lower than a SB and I'm afraid I'll end up with rubbing at 255.
Old Aug 5, 2008 | 08:55 AM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
These are 245 60 all the way around on stock ralleys.
Old Aug 5, 2008 | 10:18 AM
sxr6's Avatar
sxr6
Same here, 235x60 fronts are only an inch shorter than 255x60s & being only slightly narrower give just enough clearance for no rubs in the front of my 69 BB car. Look perfect IMHO
Old Aug 5, 2008 | 09:07 PM
70454Convert
I like the looks of those 245's. Definitely going with those.
Is your car stock height or did you lower it?
Old Aug 5, 2008 | 09:21 PM
trw's Avatar
trw
245x60 fronts and 255x60 rears. The 245's are about 1" smaller diameter than stock, slight difference for speedo.
Old Aug 5, 2008 | 10:17 PM
c69vete's Avatar
c69vete
St. Jude Donor '07
The front I have not touched. The rear I am running the 8" bolts.
To Tire selection
