Enging and Undercarriage Cleaning
Old Aug 12, 2008 | 10:23 PM
jayst1's Avatar
jayst1
Default Enging and Undercarriage Cleaning
My 79 vette came from GA and although has no real rust, the engine is very dirty and the undercarriage is full of the lovely White Georgia Sand packed on it. What is the best way to clean my enging and Chasis? When I was in the Marines we used simple green to clean our Light Armored Vehicles, and we used wire brushes to bust the rust then painted over it with rustoleum. Am I on the right track? Can I just spray degreaser on my engine block then hose it off as long as I keep the wires dry? Thanks!!
Old Aug 12, 2008 | 11:53 PM
noonie's Avatar
noonie
I used the purple stuff degreaser but simple green works too. Used a short pressure cleaner wand. Did it repeatedly for 2 days and wore a rainsuit with car jacked up. Got every nook and cranny possible.
Well worth the effort. Just let it dry well before running. I waited a few days.
Be glad it's just the Georgia white sand and not the red clay.
Old Aug 12, 2008 | 11:59 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Are you doing this at home? If so, lay down some plastic. Crud will get everywhere. A high presurre hose works great. Spray two or three cans of engine degreaser everywhere the night before and let it soak in. Then the high pressure hose will knock it off with ease.
Don't forget to clean out your ears after.
Good luck!
Old Aug 13, 2008 | 12:04 AM
r3rep's Avatar
r3rep
Be careful. Make sure your cleaner is safe for aluminum. I think that Purple stuff has a warning against use with aluminum. Simple Green should be good as IIRC states is safe with aluminum
Old Aug 13, 2008 | 09:49 AM
jayst1's Avatar
jayst1
Okay. Is there anything i should avoid getting wet? I have a gas powered pressure washer. Is it okay to use that on a low setting? Thanks!
Old Aug 13, 2008 | 10:42 AM
noonie's Avatar
noonie
I used 3500 psi.
When trying to start engine either take plugs out and crank or bump over completely, very slowly with ignition power disconnected.
Old Aug 13, 2008 | 10:45 AM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
I use engine degreaser and heavy duty cleaner on mine. I get it warm, then spray on the soap, then take it off with the power sprayer. I try to do it on a warm sunny day so any electrics will dry out if they get wet. I don't cover anything or worry about wires, etc. I have seven vehicles and wash them all this way, including my 91 (L98).
If it is really bad it may take several attacks with the power sprayer to get it clean. Remember, it didn't get on there in one day......
Now be a good boy and fill out your profile.....and show us before and after pics of the engine bay...
Old Aug 13, 2008 | 01:29 PM
jayst1's Avatar
jayst1
Okay.....I did as I was told..... I didn't even realize I had a profile....I will post engine pics soon.....I posted exterior and interior pics of my mess......I have lots of work ahead of me.
Old Aug 13, 2008 | 04:52 PM
RagTop69's Avatar
RagTop69
The before pics will make a great display when showing the car later. I have photos of my 69 Mustang's engine compartment as it stood the day I bought it. One of the P.O.s must have blown an upper radiator hose and the whole engine bay was coated in a layer of dried rusty water. When people compare it to the engine compartment now, I always gets lots of positive feedback. Fortunately my Vette was cared for prior to my owning it. The compartment was pretty clean when I bought it. I've got one of those steamers that they advertize on infomercials and I used it on the engine to get the light dirt and grease off of the painted areas. Looks pretty good.
Old Aug 13, 2008 | 08:44 PM
tnovot's Avatar
tnovot
I always cover the distributor and carb with air cleaner removed and either wrap a cloth or plastic bag around the alternator. These can be cleaned by hand later if necessary while everything else is drying out.
Terry
Old Aug 13, 2008 | 09:10 PM
luerja's Avatar
luerja
Get it done right... I never had an issue taking it somewhere professional to do the cleaning. This is better than Mr. Spary can can in a hand engine degreaser and a garden hose. $175.00 complete ... that's everything top and bottom
Old Aug 13, 2008 | 09:52 PM
eastltd's Avatar
eastltd
Cool picture Jim
Old Aug 14, 2008 | 02:37 PM
7T1vette's Avatar
7T1vette
Steam cleaning the undercarriage is the best way to go. You don't have to do any of the work and all the old road dirt, tar, grease, etc. is GONE ! Just make sure they know what they are doing when working on a 'vintage' car and ask them not to use too much pressure on non-frame items. [It is a good idea to bag up the distributor and carb/air cleaner before they shoot it. It also wouldn't hurt if you turn off the battery disconnect (if you have one).]
Old Aug 14, 2008 | 02:46 PM
SharkintheWoods's Avatar
SharkintheWoods
On those very stubborn baked on parts, I used oven cleaner, but make sure you don't get it on polished aluminum and watch the times you leave it on cast aluminum. It is nice since it will go ahead and take the paint off as well if you want to repaint. Be very careful with the splashback though, it is not very skin friendly.
Old Aug 14, 2008 | 03:03 PM
luerja's Avatar
luerja
Originally Posted by eastltd
Cool picture Jim
Thanks... Here was my 77 cleaned up
To Enging and Undercarriage Cleaning
