Wheel Identification Numbers
Old Aug 30, 2008 | 07:09 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Default Wheel Identification Numbers
I removed the tires from my five wheels off of my 1977 Corvette today. They are ralley wheels and I would like to clean them up and repaint them. Is there a way to look at them and see when they were manufactured and whether or not they are Kelsey Hayes wheels?
Also, does anyone know if the spare was supposed to be the same size as the mounted wheels, mine appears to be narrower. Odd.
Can anyone help me withi this please?
Thank you.
David Howard
77Sleeper
Old Aug 30, 2008 | 08:23 PM
LYLE's Avatar
LYLE
Thank you.
David Howard
77Sleeper
In the center near the lug nut hole you should see K 1 6 or 7 for 1976 or 7.
At the valve stem it should have K17 or 6 then 1-12 for the month valve stem 1-31 day of month and AZ = 15X8 Corvette rim. Your 77 would have had 5 GR-70-15 tires from the factory all the same size.
Old Aug 30, 2008 | 08:42 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Thank you Kyle, great data. The mystery continues. Four of my wheels have 15X8 stamped in the body of the wheel and the codes K15 on them which I assume means manufactured in 1975. They do say AZ but I cannot real the other data, have to clean them up more. Those four measure 8" on the inside lip to lip.
My sneaky little spare tire is not the same. It has the code K18 and it is one inch narrower, that is, 15X7. Again I cannot see the data near the valve stem until I clean them up better but someone slipped in a narrower wheel. Does this mean the spare was from a 68? All four of the tires were 225/70R/15's that I had removed.
Any suggestions on this one?
Thanks again.
David
Old Aug 30, 2008 | 11:11 PM
CCrane65's Avatar
CCrane65
Thanks again.
David
Your spare is a 68 rim. The change to 15x8 was made in the 69 model year.
Yes, the 5 means it was manufactured in the 1975 model year and BTW in case you didn't pick up on it the K means Kelsey Hayes and the 1 means it is a Chevrolet wheel.
cc
Old Aug 31, 2008 | 07:02 AM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
cc
Both of my 1977 models were built and delivered in late 1976 so I guess having wheels from 1975 could and weuld make sense. The spare however, does not. Do you know if they put the same sire GR70/15 tires on the 1968 and 1969 models that came on 1970-77?
I will clean this one up with the other four and will either sell it, replace it with a correct year, or swap it.
Thanks for all your help, much appreciated.
Best regards,
David
Old Aug 31, 2008 | 08:58 AM
Duke94's Avatar
Duke94
From "Corvette by the Numbers"
Old Aug 31, 2008 | 10:34 AM
LYLE's Avatar
LYLE
Best regards,
David
Your 77 built in late 76 would not have never had 75 rims as most are dated 2-6 weeks before the build date. 75 rims would be a year or more too early. GR-70-15 were radial tires and the first year was 1973 when radials replaced bias ply. That spare could be a 78 space maker tire as this was the start of donut spares.
To Wheel Identification Numbers
