TKOs...free shipping....
Old Sep 3, 2008 | 10:25 PM
vettesbydesign's Avatar
vettesbydesign
Default TKOs...free shipping....
I am getting ready to run a group purchase on all the TKO 500s/600s/600RR,and the T56,and the T56 Magnums.
I was notified today by Tremec that as of Oct.1st the "flooring price" for dealers,and authorized resellers will be going up,so I am going to offer a group purchase before the price increase.
If I get 3 of ya all that buy the kits,then I will cover the shipping myself.
Tomorrow I will add to this,and add pics of my kits,and the pricing.
Old Sep 4, 2008 | 05:27 PM
vettesbydesign
OK....here's the new prices as of October first,so this sale is from now until Sept.30th.ALL money has to be cleared,and available on the day of Sept.30th!
New retail floor pricing for all TKO dealers,and authorized resellers....
1.T5....1295.00
2.TKO 500....2095.00
3.TKO 600/TKO 600RR....2195.00
4.T56....2595.00
5.T56 Magnum....2795.00
This about a 10% increase across the board.This is the bottom retail price from every dealer/reseller.
I can't speak on the other companies,but I am able to save you money on the kit aspect,or the upgrades to more performance ariented parts.
Free shipping from now until Sept.30th,2008 when 3 or more of ya all get together for a group purchase.
I have the following in stock,and ready to go.....
1.TKO 500-1
2.TKO 600-9
3.TKO 600RR-2
4 to 5 speed Conversion
TKO 500....$2995.00
TKO 600....$3095.00
TKO 600RR.$3095.00
includes.....
1.TKO 500/600/600RR
2.Quick release slip yoke w/Spicer 1350 U-joint
3.Modified crossmember bracket
4.Trans mount
5.Speedo adapter
6.Backup light wiring harness
6.Needle bearing pilot bushing
7.Shifter handle w/correct ball(specify year ,please)
8.Shift pattern indicator
Auto to 5 speed Conversion
TKO 500....$3829.17
TKO 600....$3908.20
TKO 600RR.$3908.20
includes......
1.TKO 500/600/600RR
2.Modified crossmember bracket
3.Trans mount
4.Speedo adapter
5.backup light wiring harness
6.Needle roller pilot bushing
7.#621 remanufactured bellhousing,11"(upgrade optional)
8.Cutch fork(includes bearing retainer)
9.Clutch fork ball stud
10.Bellhousing rubber boot
11.Inspection cover
12.Middle performance clutch kit(upgrade optional)
13.Flywheel(upgrade optional)
14.Shifter handle w/correct ball(specify year,please)
15.Shift pattern indicator
16.bellhousing bolt set
17.bellhousing to trans bolt set
18.Pressure plate to flywheel bolts/washers
19.Inspection cover bolts
20.Pedals w/housing(used)w/new pedal pads,bushing kit(4pc),and retaining clip.
21.Z-bar
22.Ball stud rebuild kit w/stud *****,zert,etc.
23.Push rod,(pedal to Z-bar)
24.Push rod firewall boot
25.Push rod swivel
26.Push rod swivel jam nuts(2)
27.Push rod to firewall return spring
28.Wire G-clip
29.Push rod to pedal spacer
30.Frame bracket(specify year for welded,or bolt on,please)
31.Fork push rod(lower Z-bar linkage)
32.Push rod to fork attaching pin
33.Push rod anti-rattle springs(2)
Optional upgrade parts/parts....
1.Shifter console(specify year,data,AC/no AC)
2.Shifter boot.....colors available
3.SFI bellhousing...add...$200.00
4.Hyd. internal McLead clutch linkage kit...add...$168.20
5.Center force 11" single disk(500 horse)...add...$151.00,or 201.00 for 12" setup
6.Center force Street twin up to 800 horse....add...$496.00
7.LS1 steel bellhousing......available
8.Cast alum bellhousing pwder coated black....$200.00
9.#621 remanufactured bellhousing....$180.00
10.Hyd.internal clutch linkage kit....$525.00
11.Modified trans mount bracket....$135.00
12.Trans mount(rubber)15.00
13.Trans mount(polyurethane)....$32.50
14.Quick release slip yoke w/Spicer 1350 U-joint....$150.00
15.Mech.Speedo adapter....$85.00
16.TKO 500 modified w/shifter....$2420.00
17.TKO 600 modified w/shifter....$2500.00
18.TKO 600RR modified w/shifter....$2500.00
19.Shifter handle,stock style w/correct ball....63-$100.00/64-67-$81.95
20.TKO 500 unmodified....$1895.00
21.TKO 600 unmodified....$1975.00
22.TKO 600RR unmodified....$1975.00
Old Sep 15, 2008 | 05:54 AM
vettesbydesign
ttt....
To TKOs...free shipping....
