Early or late 69 Corvette
Old Sep 18, 2008 | 01:42 PM
jick&mudy's Avatar
jick&mudy
Default Early or late 69 Corvette
According to C3 Registry, my 69 was born app. Dec. 23, 1968. I see vendors offering parts, etc. differeciating between early and late. My questions are: is mine early or late? I assume early. And what are the differnces? I'd appreciate any thoughts or suggestions. THANKS! mick
Old Sep 18, 2008 | 01:51 PM
luerja's Avatar
luerja
yours is early. GM had a strike in that year and it pushed the production out till December 1969.
not sure on differences between the two
Old Sep 18, 2008 | 02:00 PM
FrankVincent's Avatar
FrankVincent
Account disabled by user request 5 Jan 09
Mick ...
As to the birth of your car, the date is located on the trim tag (driver door alcove) .. Would look like E20 maybe ... ???
As to early or late, it's not the date of the car that is early or late, it all depends on the particular part ... the easiest way to tell is to use your AIM to see if, and when, a particular part changed. Some vendors also will tell you how to differentiate whether a particular part for your car is "early" or "late".
For some parts, your car may be considered "early", and for other parts, it may be considered "late". DrRebuild usually does a nice job of explaining what makes a car early or late.
... and for some parts it may not matter whether you choose the early or late part, as either may work. If you plan to have the car judged, then it can make a difference.
Old Sep 18, 2008 | 02:01 PM
Les's Avatar
Les
Mine's early too although I don't know how to determine it's production date- I'd love to find out.
I've found that my car came with brackets & grills from the 68 production. The only parts that would be used would be small ones like this that were left over and wouldn't make any real difference cosmetically or functionally. They differ slightly from those made for the 69 run. I hope this helps. Somebody who's more into NCRS type stuff may be able to give you a more detailed answer.
Old Sep 18, 2008 | 02:18 PM
RobRace10's Avatar
RobRace10
Later 69 cars came with headrests it was an option early in the year. Also the wiper door actuator was much larger on the early 69 cars.
Old Sep 18, 2008 | 03:16 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
"Early" and "late" usually refer only to specific running changes made during production. The Assembly Instruction Manual (AIM) is one of the better guides for determining early and late since AIM pages were updated regularly with new parts/changes and the pages have revision dates.
If you do not have an AIM, buy one and thumb through it. I can recommend Rick Bizzoco's book on the '69. Pricey, but pretty good.
http://www.cranescorvette.com/1969_s..._guidebook.htm
12/23/68 was a Monday and possibly the last working day of that week since it's likely they were off Christmas Eve and Christmas Day. Your car was probably not completed on 12/23 and it's possible she sat on the line unfinished until after Christmas. 12/23 only indicates the date the car reached the station on the line were the trim tags were attached. This was before body drop. She probably needed another day, possibly a day and a half, to have been completed.
It's kind of sad to think she spent her first Christmas without a home.
Old Sep 18, 2008 | 06:00 PM
Alan 71's Avatar
Alan 71
Hi Les,
You can look at the trim tag mounted on the drivers side hinge pillar in the door jam to see the body's build date. The car's build date is generally a day or so later. There are production figures by month that can help narrow down production date too.
Regards,
Alan
Old Sep 18, 2008 | 06:02 PM
schmegeggie's Avatar
schmegeggie
Any 69!!!
It IS the best year of the C3...
Old Sep 18, 2008 | 08:07 PM
Les's Avatar
Les
Originally Posted by Alan 71
Hi Les,
Regards,
Alan
Alan,
You inspired me to go down to the garage and look it up. I had to pull out my "Vette Vues" to decode the "B"- Sept. 5, 1969 for mine. You learn something every day. Now I know that I have just under a year to plan a surprise 40th birthday party for it. Thanks!
For some reason my wife is in the kitchen laughing at me right now.
Old Sep 18, 2008 | 08:14 PM
69small block's Avatar
69small block
Originally Posted by schmegeggie
Any 69!!!
Old Sep 18, 2008 | 08:56 PM
FrankVincent
Originally Posted by Les
Alan,
If your trim tag says "B05" ... that is September 5, 1968.
Happy Birthday!!!
Old Sep 19, 2008 | 12:46 AM
Les's Avatar
Les
Happy Birthday!!!
Doh! If I only had a brain...and I used to be good at math. OK, tomorrow we have cake & balloons!
Old Sep 19, 2008 | 09:52 AM
dbeall1968's Avatar
dbeall1968
Buy her something nice for her B-day!
Old Sep 19, 2008 | 01:09 PM
RagTop69's Avatar
RagTop69
My late 69s build date is October 16, 1969. I haven't checked it myself, but would that mean the date code on my door tag would be "O16"? (The car's not available to look at right now or I'd check it myself.)
Old Sep 19, 2008 | 01:36 PM
FrankVincent
That's correct ... !!
Old Sep 19, 2008 | 11:47 PM
6t9427's Avatar
6t9427
Any 69!!!
To Early or late 69 Corvette
