How To Stop Rust...?
Old Sep 27, 2008 | 05:51 PM
SteyrAUG's Avatar
SteyrAUG
Default How To Stop Rust...?
Ok, nothing major, but my corvette came from Iowa and has a bit of rust going on.
What is the best way to STOP it?
And preventative maintenance I can do to keep it from getting worse?
Old Sep 27, 2008 | 05:53 PM
BeachSide76Vette's Avatar
BeachSide76Vette
Move to Arizona?
Old Sep 27, 2008 | 05:59 PM
72LS1Vette's Avatar
72LS1Vette
I use RustBullet and Eastwood Rust Encapsulator to treat metal parts. Some people prefer POR products but IMO RustBullet is much easier to use. You can treat the inside of your frame with an Eastwood product or just spray some oil inside the frame. If done annually it will probably work as well as anything else.
Nothing will absolutely stop rust - it's Mother Nature's way of getting her stuff back but you can slow down her progress quite a bit.
Rick B.
Old Sep 28, 2008 | 12:17 AM
SEVNT6's Avatar
SEVNT6
Nothing works better than nice dry roads.....
Like in Arizona.......
Old Sep 28, 2008 | 02:36 AM
rcread's Avatar
rcread
I've found that cutting it out and replacing it with sound metal usually works.
Old Sep 28, 2008 | 11:20 AM
Alan 71's Avatar
Alan 71
Where is the rust? That could have a bearing on how you should deal with it.
Regards,
Alan
Old Sep 28, 2008 | 11:33 AM
moosie982's Avatar
moosie982
Regards,
Alan
Alan,
Great answer, once again the sane voice of reason shows its self. Thank God for members like you, my faith in the Corvette brotherhood is renewed. Peace,,,Moosie
Old Sep 28, 2008 | 12:53 PM
DEMITRISTYLES's Avatar
DEMITRISTYLES
From: You Can't Buy Cool, No Friggin' Way - Mississauga Ontario
Originally Posted by moosie982
Alan,
Old Sep 28, 2008 | 01:45 PM
SteyrAUG's Avatar
SteyrAUG
Regards,
Alan
Underneath the car, looks like the main structure.
Old Sep 28, 2008 | 02:46 PM
jerwarn67's Avatar
jerwarn67
8th Gear
POR 15,Ospho,Navel Jelly
Old Sep 28, 2008 | 02:58 PM
Alan 71's Avatar
Alan 71
At this rate this could go on till the rust IS a problem.
I assume you're referring to the frame.
Is the rust just on the surface? Is it the same everywhere? If you tap on the frame where the rust is with a small hammer do you get a nice solid sound or a thud? Is the rust thick enough anywhere that it's starting to form flakes?
Could you have someone who knows about Corvettes look at it and tell you what you have.
A few picture sure would be a help!
Regards,
Alan
PS: No help on your profile. Did you make your signature scary for a particular reason?
Old Sep 28, 2008 | 06:32 PM
SteyrAUG's Avatar
SteyrAUG
Regards,
Alan
Yeah, I know I need more details.
And why do you find my signature scary?!?
Old Sep 28, 2008 | 07:02 PM
Alan 71's Avatar
Alan 71
I wonder why you think we want or need to know all that about you.
I much rather know about your car, since that's why I'm here.
Regards,
Alan
Old Sep 28, 2008 | 07:06 PM
BigBlockTank's Avatar
BigBlockTank
Regards,
Alan
Old Sep 28, 2008 | 10:51 PM
wjsullivan's Avatar
wjsullivan
Place car in air tight storage facility, apply vaccum to remove all air, never drive again....
OK seriously. Check out the Eastwood rust system. Converter should stop the spreading, encapsilator should cover it up and keep it from getting worse or converting again and then paint.
worked great on my '75
Old Sep 29, 2008 | 01:23 AM
SteyrAUG's Avatar
SteyrAUG
Regards,
Alan
Simple enough, standard sigline I use on any forum. Born from the fact that my diverse views don't quite seem to fit in with any crowd.
As for my car, it's a 1980.
Old Sep 29, 2008 | 02:22 PM
7T1vette's Avatar
7T1vette
If the rust is on the frame, just get underneath the car with a small ball-peen hammer. Use the 'flat' side to tap on the rusty areas to see of the metal resonates with a ringing sound or a dull thud. If it sounds like solid metal, turn the hammer over to the peen side and rap it again. If you don't get any denting or lots of rust falling out of the frame, it's likely to be pretty solid. If you have to sweep up the rust...you're too late to stabilize it with "Rust Bullets".
Old Sep 29, 2008 | 05:21 PM
SteyrAUG's Avatar
SteyrAUG
I don't think it's too far gone, looks like mostly surface rust. It was stored winters. I need to get under it this weekend to see exactly what is going on.
And seriously, thanks to all those who provided answers to my very general and less than detailed questions. I now have a basic direction to start working in.
To How To Stop Rust...?
