cowl
Old Sep 28, 2008 | 06:34 PM
timd02's Avatar
timd02
Default cowl
Can anyone tell me if the area below the windshield where the wiper arm are located is called the cowl? I have cleaned out the debris from this area and I have water that will drip(not much accumulation) in the floorboard. What is the material/coating that is in this area and are there any pointers as to find where the leak is coming from? Thanks for all your help.
Old Sep 28, 2008 | 06:40 PM
TimAT's Avatar
TimAT
I've had fair luck using a soapy water spray. Close everything up with the heater fan on high, spray soapy water where you suspect the leak- see if you can find bubbles.
Yes, that is the cowl..
Old Sep 28, 2008 | 06:56 PM
Alan 71's Avatar
Alan 71
Hi Timd02,
People have good success using roofing cement/sealer from the local Home store to seal-up the wiper well. You should be very generous with it as GM was.
Regards,
Alan
To cowl
