1972 Steering Column
Old Sep 30, 2008 | 12:14 PM
Elkhartgreen72's Avatar
Elkhartgreen72
Default 1972 Steering Column
Hello gang,
As most of you know, I am restoring a 72 coupe. I am up to the steering column. It's out of the car , on the work bench. It is a straight column, no tilt, no tele. Just a turn signal. The wheel is off, the rag joint is off. (both are easy enough). I might add, I could send it out but I would like to tackle it myself. I have been looking for a diagram of the parts in order, but can't find one. Does anyone have one thay can send me? Also the main bolt of'course spins the shaft. What's the best way to unbolt that? I would like to completely dis assamble it, restore each part and re assemble and repaint it. I'm just asking for anyones advice that may have done this job before. Any pit falls I may run into. Any short cuts, any sequence I might need to follow.
Thank you in advance
Elkhartgreen72 (Dave)
Old Sep 30, 2008 | 03:04 PM
Alan 71's Avatar
Alan 71
Have you tried searching for 'Jim Shea'? He's THE column man!
Regards,
Alan
Old Sep 30, 2008 | 04:27 PM
avner's Avatar
avner
Take a look at Jim Shea papers:
http://jimshea.corvettefaq.com/?page_id=4
Avner
Old Sep 30, 2008 | 04:34 PM
MakoShark72's Avatar
MakoShark72
Elk,
I'm in the same boat as you, but I am switching to a TT...I read Jims papers, very helpful, but I thought the diagrams left a bit to be desired. Take a look at Doc Rebuild's diagrams in the catalog. They are about the clearest I can find..Hope this helps..
Doc's index, look under S...
http://www.docrebuild.com/dr-r-web/indexx.html
Standard column..
http://www.docrebuild.com/dr-r-web/ST-COL3.PDF
Old Sep 30, 2008 | 05:21 PM
Alan 71's Avatar
Alan 71
Hi MS72,
Did you know that the good doctor does all the drawings in the catalogue himself?
I think they're amazing. For many things his drawing is clearer than a really good photo would be.
Now that he's sorta retired you don't even get yelled at so much when you call.
Regards,
Alan
Old Sep 30, 2008 | 05:32 PM
MakoShark72
Originally Posted by Alan 71
Hi MS72,
Regards,
Alan
Alan, I must admit I havent ever called them (him) but his catalog is invaluable for its diagrams....Hadnt heard that it was hand-drawn, now thats impressive!
Old Sep 30, 2008 | 05:53 PM
Rickman's Avatar
Rickman
God bless Doc Rebuild. He forgot more about C3's than I will ever know. He was very helpful some years back regarding the restoration of my 72- spent 15 minutes or so discussing my options at Corvettes at Carlisle.
Rickman
Old Sep 30, 2008 | 09:04 PM
R1234's Avatar
R1234
Originally Posted by Elkhartgreen72
Hello gang,
Hello Dave,
I rebuilt my 1968's standard column. The 68 was a pretty easy task. I ordered my parts from Corvette Steering. I purchased the upper bearing/housing assembly and the lower bearing kit. When you do the upper bearing, document the order of parts as they come off. The lower bearing kit comes with assembly instructions.
The hardest part is beating the lower bearing out of the column housing. The 68 column housing has a notch at the lower end that allows you to put a screw driver or chisel on the bearing flange so you can beat it out with a hammer. I sprayed some liquid wrench on it the night before to help it break loose from the column housing.
Old Sep 30, 2008 | 10:29 PM
724544SPD's Avatar
724544SPD
I'm just wrapping up overhauling my the tilt/tele column from my 72. I used the diagram in the GM service manual. It shows all of the parts in order and has useful information that will help you with the process. I blasted the external parts and soaked the rest in solvent. It went back together easy enough. I'm glad that I went to the trouble, it was pretty nasty on the inside...hardened grease, grime etc... Good luck on yours!!
Hello gang,
Old Oct 1, 2008 | 08:03 AM
markdtn's Avatar
markdtn
I have bought a lot of parts from him. Always good parts. The diagrams are invaluable. I put that catalog on the must-haves list with AIM and Factory Shop Manual. Did not know they were hand drawn, that is impressive.
Old Oct 2, 2008 | 03:51 PM
76vette454's Avatar
76vette454
Just checking to see if my Avatar came up.
To 1972 Steering Column
