Steering wheel question
Old Oct 9, 2008 | 04:39 PM
basketcase69's Avatar
basketcase69
Default Steering wheel question
I have a steering wheel off a 69, im getting ready to sell and noticed something im not sure is normal. The wheel appears to be bent, if I lay it flat on a table, the part of the wheel that meets the center cross braces is about 1/4 inch off the table on both sides. Is this normal or has the previous owner bent this somehow?
Old Oct 9, 2008 | 04:45 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
it should look more like a step. if it does thats how all 67-? should look
Old Oct 9, 2008 | 10:39 PM
basketcase69
I cant say it looks like a step, might just not be understanding what you mean. With this one, if I lay it on the table it is off the table where the center ribs meet the wheel. Hard to explain.
Old Oct 10, 2008 | 08:38 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Post a pic. '69 wheels are 15" diameter black plastic on a metal frame.
Old Oct 31, 2008 | 11:50 AM
basketcase69
Here is a pic of it, where the center ribs meet the wheel, there is a slight bend to the right. Is this normal or has the previous owner pulled on it hard enough to bend it?
Old Oct 31, 2008 | 12:45 PM
RagTop69's Avatar
RagTop69
A related question. My 69 has a stock 15" steering wheel with a black leather wrap. A friend of mine has questioned whether the wrap is stock or put on by a prior owner. this is a one piece wrap with stitches on the inside of the wheel, not one of those parts store spiral wraps with the air holes in it and the plastic to hold it on the wheel. I took one of those off of my 69 Mustang vert and I know they are aftermarket. Does anyone know if the 69 Vette had a leather wrapped wheel as an option?
Old Oct 31, 2008 | 02:41 PM
427basketcase's Avatar
427basketcase
My stock 69 wheel is perfectly straight when placed on a flat surface. The leather wrap is not factory, sounds like a Pelton job, or I have seen kits to do the same thing (eliminates the sticky that happens to those)
Just my opinion and experiences.
Old Oct 31, 2008 | 05:47 PM
7T1vette's Avatar
7T1vette
Maybe the PO made a panic stop and bent the frame a bit.
Old Nov 2, 2008 | 09:31 AM
basketcase69
I would think that too but its bent towards the driver, he must have pulled on it pretty hard. Now I just need t figure out how to staighten it without doing damage. Any ideas?
Old Nov 3, 2008 | 09:38 AM
southern_vette's Avatar
southern_vette
Mind 69 did the same thing, it starts off bent just a little, leave it out side in the sun with the top down and the heat will draw it to the point the SS ring will pop off. I could not find a way to repair short of buiding a new repro Steering whell.....
To Steering wheel question
