well... it's low
Old Oct 14, 2008 | 05:51 PM
  #41
Trucks_69's Avatar
Trucks_69
Originally Posted by 68 NJConv 454
Got any pics of your setup?
I'm curious, you'd have to go with a telescoping halfshaft or solid axle or you'd pull the halfshaft clip right out when you went to raise the car.
I appreciate what you're doing. I appreciate when anyone is willing to put some elbow greese into something to get what they want. Would love to see some pics of your setup underneath.
actually that's not intirely accurate, it has the stock half shafts... and they donnot "slide out"... they weren't designed that way
if that was the case everytime you hit a good sized pothole, they'd fall out...
thanks for the positive feedback tho
Old Oct 14, 2008 | 09:06 PM
  #42
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
I'm diggin it bro, keep the pics coming, I can apppreciate the effort and work it takes to create something different and unique.
Old Oct 14, 2008 | 10:05 PM
  #43
Jclgodale3's Avatar
Jclgodale3
Originally Posted by Trucks_69
but not everyone can have a custom built with fab work that took blood sweat and tears to build, so don't hate... apperciate!
I agree with this
i already have 3 magazines just dying for a cover shot
3 lined up already? really??? do tell! Who?
Old Oct 14, 2008 | 10:39 PM
  #44
Trucks_69's Avatar
Trucks_69
Originally Posted by Jclgodale3
I agree with this
Gauge Magazine is one
Drop Jaw Mag is another...
those 2 are online, but deff. worth it
Hot Rod Mag
and Rod & Custom are also interested in the project
Old Oct 14, 2008 | 11:22 PM
  #45
DEMITRISTYLES's Avatar
DEMITRISTYLES
From: You Can't Buy Cool, No Friggin' Way - Mississauga Ontario
Can you post some pics of your setup. PM me the cost if you don't mind.
Thanks.
Old Oct 15, 2008 | 02:09 AM
  #46
68 NJConv 454's Avatar
68 NJConv 454
Yeah but you have some serious travel there. I would estimate close to or over 4 inches from drop to 4x4 height. I can't imagine the stock halfshaft having that much play in it.
To run the car lower than stock have you adjusted the height of the differential to correct your halfshaft angles? Meaning with your car dropped to the heigh you want it, are your halfshafts still parallel to the ground? When those halfshafts go to funky angles it puts major stress on the Ujoints which could give you a premature suprise when a broken halfshaft comes to visit your battery/storage tray. I've been battling the halfshaft angle/ride height issue to the point that I have the ride heigh a little higher than I prefer b/c I want my halfshafts at the proper angle. Eventually i will look into raising the differential to get my desired ride height. I assume pics of your setup are privledged information for the time being?
Old Oct 15, 2008 | 01:24 PM
  #47
Enersis's Avatar
Enersis
I'm jealous, I have always wanted air ride on my vette!
Beautiful car man
Old Oct 15, 2008 | 05:31 PM
  #48
Trucks_69's Avatar
Trucks_69
yes u are right... at ride height the shafts are parallel to the ground and i never plan on driving at full lift nor at full drop so i'm good in that department
yes the rear and front bag setups are classified info at the moment
Old Oct 15, 2008 | 05:32 PM
  #49
bj1k's Avatar
bj1k
Originally Posted by moosie982
It looks broken with the wheels tilted in @ the top like that, I like 'em low but I dont like 'em look'n broken. It'll look awsome raised just a touch, Peace,,,Moosie
And it will drag on every bump in the road. I know, my side pipes sat that low and I had to remove them after a few days. It will take a lot more to change that one back.
Old Oct 15, 2008 | 05:37 PM
  #50
Durango_Boy's Avatar
Durango_Boy
So the entire air and bag system is for sitting still only? Like sitting in traffic? Car shows? Can the car raise and lower itself if you are not in it? Like maybe with a remote fob?
Old Oct 15, 2008 | 05:41 PM
  #51
onaqwst's Avatar
onaqwst
most airbag setups are used for shows...... unless you really want to drag/sparks/etc ....most riders will adjust to ride height when cruising and might slam it at a light or when parked....
theres different air management setups...... fronts/back/side/ full corners..... all depends on the use and how much you want to do with it....
b
Old Oct 15, 2008 | 05:45 PM
  #52
Durango_Boy
b
How much does an average bag setup cost? Assuming the OPs is better than average, how much would someone pay if they wanted to bag their Vette and still did some of the work themselves?
Old Oct 15, 2008 | 05:56 PM
  #53
onaqwst's Avatar
onaqwst
i'm guess around 1500...... tank/compressors/gauges/etc..... then some fabrication on your end..
i was gonna bag mine...then was thinking of just doing the front.....
Old Oct 15, 2008 | 06:04 PM
  #54
V-Twin's Avatar
V-Twin
Let's see some of those fabrication pics
Old Oct 15, 2008 | 06:40 PM
  #55
DEMITRISTYLES
Old Oct 15, 2008 | 06:42 PM
  #56
DEMITRISTYLES
I think that's all I want is the front done just to get over high speed bumps and in/out of low driveways.
Old Oct 15, 2008 | 06:49 PM
  #57
onaqwst's Avatar
onaqwst
yeah...then you can get away with a simple setup then......
you just need 2 airbags/small tank/1 compressor/1 valve/gauge/1 switch...easy
you might even be able to order that setup for cheap too...... check craigslist
To well... it's low
Old Oct 15, 2008 | 06:53 PM
  #58
Domer's Avatar
Domer
Looks like you've done a heck of a lot of work...looks great! Can't wait to see the final deal with new paint and wheels...I did a custom interior for my '77, so I know the gratifying feeling of accomplishment...besides you did it for yourself...right!
So...Enjoy the fruits of your own labour!
Domer.
Old Oct 15, 2008 | 07:33 PM
  #59
PhyscoVette's Avatar
PhyscoVette
Air bag setups can range by alot! I have designed and installed several setups and I can tell you most of them were in the 8k range for a full on custon setup. The cheapest setup was on a thunderbird and it was still 2500.
Old Oct 15, 2008 | 08:18 PM
  #60
Terrys69coupe's Avatar
Terrys69coupe
That looks great !
