interior panel opnions
Old Oct 21, 2008 | 09:39 AM
1nicecorvette's Avatar
1nicecorvette
Default interior panel opnions
stock or not? i have the center T-top panel with a slight warp at the back window that sets it off from the rest and maybe the halo panel. My question to all off you is would replacing the ineterior panels with aftermarket still retain the value? i would think no. plus the color would be off (fading dirt etc.)
now question two- would there be a difference in panels from the same year and car part number or manufacturing number / code wise?
Im really on the fence of replacing the interior panels but then again want to keep the originality. opinions?
Old Oct 21, 2008 | 09:53 AM
Durango_Boy's Avatar
Durango_Boy
New T-top panels usually are plastic backed and stock panels were fiber backed. There will also usually be a sticker by the manufacturer if it's a remanufactured part.
Old Oct 21, 2008 | 12:26 PM
GD70's Avatar
GD70
How badly warped? You can try using a hair dryer to soften it or place it in the sun first to soften it up a bit, then weight the warped area so it straightens out some. You'll need to let it sit for several days at least. I did this with one of my T-top panels and it helped.
Glenn
Old Oct 21, 2008 | 01:23 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Can you live with it? If it's not too bad, I believe I would keep what I have.
Old Oct 21, 2008 | 01:49 PM
blckslvr79's Avatar
blckslvr79
Are you talking about the center panel between the T Tops?
The one that runs from the windshield to the rear glass?
The one with the dome light in it?
Find a used one in good shape. I found one on Fleabay for like $40.
Perfect shape. My old one was also sagging at the back edge along the glass. The cardboard backer was shot.
You can spray dye these really easy to match your interior.
No one would know any different.
Old Oct 21, 2008 | 02:47 PM
1nicecorvette
YEAH I CAN CERTAINLY LIVE WITH IT. HECK ITS 30 YEARS OLD! IM SAGGING TOO AT 38!! lol
but i guess what i was getting at is how many of you had replaced your interior only to look back and say "man why did i do that!"
Old Oct 21, 2008 | 02:54 PM
GD70's Avatar
GD70
Like I said before, see if you can fix the warp. Original parts ALWAYS fit best.
Old Oct 21, 2008 | 04:52 PM
Alan 71's Avatar
Alan 71
From what I read new interior trim pieces look nice because they're NEW. But people often say that they don't fit well.
I agree with the thoughts to try repair and use what you have.
Regards,
Alan
To interior panel opnions
