Vacum problem
Old Oct 21, 2008 | 12:41 PM
Hurri's Avatar
Hurri
Default Vacum problem
Working on a 70 350/350 car for a friend. At idle the wiper door and both headlight doors want to pop up. As soon as you rev it they will start to close and driving down the road they will remain closed. As any one fooled with this problem? Any ideas?
Old Oct 21, 2008 | 12:47 PM
PETKAH's Avatar
PETKAH
Had the same thing happen with my '70 at startup. In my case it was a simple matter of making sure all hose connections are firmly on. Check hose on manifold, and make sure the rubber plug on the front of the wiper canister is firmly on - if not get a new one. The, the list goes on ...
Old Oct 21, 2008 | 01:10 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Metal check valve between the manifold and the firewall.
Old Oct 21, 2008 | 05:15 PM
Alan 71's Avatar
Alan 71
Hi H,
My thought is that there's a slow leak in the control side of the system. At idle the vacuum isn't high enough to keep up with the leak, at high RPM's it is. A check valve leak as Mike suggests, a hose leak as PK suggests, or maybe a relay leak?
Regards,
Alan
Old Oct 21, 2008 | 08:55 PM
...Roger...'s Avatar
...Roger...
Try bringing the rpms up slowly until the lights and wiper doors close down and hold that rpm,with a pair of pliers pinch off the hose between the manifold and 3 port metal check valve and watch what the lights do.If they stay down,replace the 3 port valve.My guess is they will come up and you have a leak in the small hose side of the vacuum system.
Old Oct 22, 2008 | 09:10 AM
Hurri's Avatar
Hurri
Default Thanks
Thanks guys,
This leaves me with no option but to fix the darn thing.
Thanks again
Old Oct 22, 2008 | 12:24 PM
Duke94's Avatar
Duke94
Most likely cause.
Old Oct 22, 2008 | 01:39 PM
7T1vette's Avatar
7T1vette
, also.
Old Oct 22, 2008 | 01:43 PM
...Roger...
Originally Posted by Duke94
Most likely cause.
Why? The engine idles at almost full vacuum,why would the checking action of the valve fix this?It almost has to have a leak that the engine needs to keep up with in the control side (small hose).Doing my pinch test will act like a new check valve was installed and will most likely show that the valve is not the problem.
Old Oct 22, 2008 | 01:48 PM
7T1vette's Avatar
7T1vette
Sounds like you want the 'logical' reason for a bad check valve acting the way it does. Well, I can't provide that...but that's what happens. Take your "good" check valve out of the system and see what happens.
Old Oct 22, 2008 | 01:53 PM
...Roger...
No reason to take anything out....just pinch the hose and instantly you have a check valve...if the lights still come up then the check valve is not the reason.
edit-I'm not saying the check valve is not bad only that I dont believe thats the reason for the headlights to pop up.The only time you really need the check valve is when the vacuum is low due to wide open throttle or you shut the engine off and you want the lights to come up.
Hurri whether you replace the valve or not make sure you replace the little white filter thats in between the valve and the manifold.This filter protects the 3 port metal check valve from engine contaminants.
Old Oct 22, 2008 | 02:16 PM
...Roger...
Exactly.....with the engine idling nothing will happen if you remove the "good" check valve and replace it with a bad one providing the rest of the system is leak free.
Old Oct 23, 2008 | 07:50 PM
BigBlockTank's Avatar
BigBlockTank
Originally Posted by Alan 71
Hi H,
Regards,
Alan
Pay attention to this man, he's on the money. I fooled with the same problem for 5 nights in a row before I found out that I had a small leak. I just replaced all the hoses with a kit. My headlights open in about 3-4 secs now, both at the same time too. Tank
To Vacum problem
