Rusty Rally Wheels
Old Oct 27, 2008 | 10:05 AM
nbean1973's Avatar
nbean1973
Default Rusty Rally Wheels
OK, I have a stock 15 x 8 rally wheel on my '73 that was not holding air. I removed the tire and out comes about a cup of rust! I'm tempted to fire up the media blaster and clean up the wheel, paint it with POR-15 and see if it holds air with a new tire. Is it worth it to attempt to repair a rusty raly wheel...or just buy a decent used one or new?
Old Oct 27, 2008 | 11:01 AM
PETKAH's Avatar
PETKAH
How old are your tires? When I first got my '70 the tires were old and would not hold air to the point - one time - the rally wheel was sitting on the ground with totally flat tire. The wheels were rusty but the problem was old tires - from reading here some people suggest replacing tires after 5 years - check the code on the tire to see when it was made.
Old Oct 27, 2008 | 01:20 PM
moosie982's Avatar
moosie982
If the tires check good & dont have any holes in them you need to take a wire brush to the portion of the wheel that the bead sits on and clean any rust or old fragments of rubber or any other trash off of the wheel and then maybe some POR15 or any other paint for that matter and you should be good to go, some tire shops will use a glue or some other kinda snot to help seal the bead but thats messy as well as UGLY, Good luck. Peace,,,Moosie
Old Oct 28, 2008 | 06:53 AM
killain's Avatar
killain
Oldtimer
Heck No ! what's your life worth? A wheel or tire that is under suspicion should be thrown out. Don't take a chance, buy a new wheel and make sure the tire is good as well. Even if your only going slow the damage when a wheel fails is catastrophic.
Old Oct 28, 2008 | 12:19 PM
7T1vette's Avatar
7T1vette
Bang on the rim with a hammer and see if any rust is knocked off the rim. If it is, pitch the rim. If not, and the sound is a clear, metallic 'ring', just clean them up. Could your tire leak be a bad valve stem/seal?
To Rusty Rally Wheels
