Body removal
Old Oct 28, 2008 | 09:44 PM
JER BEAR's Avatar
JER BEAR
Default Body removal
Taking body off frame was told to put floor jack under to start lift. Where do you put the jack at?
Old Oct 28, 2008 | 09:50 PM
depdep3's Avatar
depdep3
I would not do it that way.
I just lifed mine a few months ago. Most folks use straps and lift from above. Lots of posts on here about it.
Old Oct 28, 2008 | 10:14 PM
JER BEAR's Avatar
JER BEAR
Thanks, i plan on using lift stripes , own 73 since 1975, i'm 63 hope not to old for this
Old Oct 28, 2008 | 10:31 PM
depdep3's Avatar
depdep3
It's a big job. I am in the middle of my first frame off. Funny but it did not cost anything to take apart, it is costing a fortune to put back together!
I don't know about you, but I am your basic backyard mechanic. Once I got it apart I realized that I would have to farm out some of the work like rear end rebuild, trailing arm rebuild, A arms, and a few others. Just did not have the equipment to do it in the home garage.
Good Luck
Old Oct 28, 2008 | 11:20 PM
...Roger...'s Avatar
...Roger...
You put the jack over in the corner of the garage.Use a hoist or lift,this is not an easy job.
http://forums.corvetteforum.com/show...576&highlight=
Old Oct 29, 2008 | 06:41 AM
vettesbydesign's Avatar
vettesbydesign
It is a big job,and expensive once the putting it back together starts,but I go this stuff all the time by myself,and w/a engine hoist.Be sure to support the frontend,bud.
Old Oct 29, 2008 | 05:55 PM
Alan 71's Avatar
Alan 71
Hi JB,
I used jacks to take the body off the frame. I jacked one side and then the other until it was high enough to roll the chassis out from under. I made some blocks of wood to slip up under the birdcage siderails, next to the frame rails.
Regards,
Alan
Old Oct 29, 2008 | 06:03 PM
...Roger...
Originally Posted by Alan 71
Hi JB,
Regards,
Alan
Wow....bet that was a job.
Old Oct 30, 2008 | 07:06 PM
Alan 71's Avatar
Alan 71
Hi DW,
Yes it was a trip.
As usual I was working by myself so I had to figure out how to do it a little at a time and without a chance of it falling on me. Also, at that point I didn't have an engine hoist yet, so that wasn't an option.
God looks out for the young and the innocent, and as I found out the old and the naive.
Regards,
Alan
Old Oct 30, 2008 | 09:02 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Actually I did the same thing, I got the body ready with 4x4's, jacked it up 1" each side.
I prefer it that way nice and slow, I also installed the 454 with no hoist. !
Jacked the frame up , rolled the motor under the frame, into place then jacked the frame into place and bolted in the motor, both worked pretty well.
Rolling chassis makes a great motor stand ! 69VETT
Old Oct 31, 2008 | 07:54 AM
vettesbydesign
69vett.....if those cranks are any good....stand those up on end,man.
Old Nov 4, 2008 | 09:27 PM
JER BEAR's Avatar
JER BEAR
Would it be better to pull motor before i lift body off frame?
Old Nov 4, 2008 | 11:12 PM
eastltd's Avatar
eastltd
If you're going to pull the body right off the frame, you shouldn't have to pull the motor.
Here's what I did:
To Body removal
