New member seeking some basic information
Old Nov 2, 2008 | 01:11 PM
69tuxedocoupe's Avatar
69tuxedocoupe
Default New member seeking some basic information
Hello group.
I recently purchased a 69 Tuxedo Black 350/350 Coupe that's a nice 57,000 mile original with repaint.
Kind of a stripper with no options other than the 350/350 and 4:11 rear.
With the low miles however, comes quite a bit of maintanence that will be needed in the way of suspension, brakes and correct detailing etc.
I plan on tearing her down over the winter and was wondering where the best place was to find information on factory correct finishes.
I'll need to get an assembly manual but curious if there's any information out there for correct component plating and or finish for cosmetic detailing.
Thanks.
John
Old Nov 2, 2008 | 01:19 PM
Mark_Milner's Avatar
Mark_Milner
Two places -
1. Vette Vues Fact Book for 1968 to 1972. Around $35 usually.
2. NCRS 1968-69 Judging Manual - About the same price, I believe.
Old Nov 2, 2008 | 01:22 PM
JBinUTAH's Avatar
JBinUTAH
And advice from this forum....PRICELESS!
Old Nov 2, 2008 | 02:25 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Some good reading below.
Are the rotors still riveted to the hubs? Original interior and pedal pads in lightly worn condition? Not an acid test, but if they aren't I'd be questioning the 57k miles thing and thinking 157k. Numbers match?
Good luck with it.
http://www.rowleycorvette.com/stats69.html
http://www.100megsfree4.com/corvette/1960/vet69.htm
http://corvettec3.ca/index.htm
http://www.islandnet.com/~kpolsson/vettehis/index.htm
Old Nov 2, 2008 | 03:52 PM
vettebuyer6369's Avatar
vettebuyer6369
Originally Posted by Mark_Milner
Two places -
and #3... 1969 Stingray Guidebook by Rick Bizzoco. Similar to the Fact Book (#1, written by M F Dobbins, actually) and more expensive, but lots more technical information.
I have 2 '69s. These 3 sources are must-haves...
NCRS website is a great place to ask direct correctness questions, too.
Old Nov 2, 2008 | 05:11 PM
Alan 71's Avatar
Alan 71
Hi 69TC,
All the literature suggestions are right on.
You should think about joining the NCRS for lots of reasons, one of which is the incredible amount of information the membership generates.
I think you're in for some big fun with your 69.
Regards,
Alan
PS: Besides the AIM you mention, you should consider getting the GM Chassis Service Manual for 69, too. Although it's not a source of finishes it IS a big help for almost anything you run into in working on your car.
Old Nov 3, 2008 | 07:49 AM
69tuxedocoupe
Originally Posted by xccter
[B]
Good luck with it.
I'm sure your right. I haven't done enough verification to make that claim. The seller planted that seed in my head. The rear suspension certainly looks patina'ed enough to be original. The brake, gas and clutch pedals look original and very slightly worn, and the odometor still works and at 57,000 and is still lined up horizontally perfect.
The interior looks like it could be original, or a slightly worn replacement, but it's hard to tell. The carpet looks replaced.
Your likely right about the 157,000 miles though.
The numbers do match on the engine and trans, I havent checked the rear but can tell it's never been out of the car.
Not sure if I like the 4:11 rear.
Thanks to everyone for the referance suggestions.
How about aftermarket parts?
Who is the best supplier for "Correct appearing" reproduction parts.
All I really know about is Ecklers and Paragon.
Old Nov 3, 2008 | 08:32 AM
Chris Farrer's Avatar
Chris Farrer
Some other vendors I have found give great service are Willcox (a supporting vendor), Dr Rebuild, and Corvette Central.
Old Nov 3, 2008 | 09:11 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Old Nov 4, 2008 | 12:09 AM
MN-Brent's Avatar
MN-Brent
Car looks sweet. Post some pics.
Use photobucket for linking them.
To New member seeking some basic information
