There, how's this? (pics)
Old Nov 7, 2008 | 07:34 PM
earthquake68's Avatar
earthquake68
Default There, how's this? (pics)
Ok, I was missing an air tank for my headlights. .....so I made one today.
Anyway, this will fit nicely right under the crossmember for the front bumper support. It's all 14 gauge steel, 4"X30" and has two brass nipples for the vacuum lines. It should work out well. I had to build up the tube with weld and then grind it smooth to create the bosses that were drilled and tapped 1/8" npt for the vacuum lines to attach to. I probably should've welded the mounting tabs on it before I painted it, but oh well, I got excited.
Anyone else want an oversized vacuum tank?
Old Nov 8, 2008 | 12:37 AM
Ed_78Vette's Avatar
Ed_78Vette
What's the GM part number?
Old Nov 8, 2008 | 04:43 AM
Dream Ride's Avatar
Dream Ride
St. Jude Donor '09
Love seein people that still improvise to make things work. Looks great!
(huh huh, he said nipples)
Old Nov 8, 2008 | 05:14 AM
joshtried's Avatar
joshtried
St. Jude Donor '08-'09-'10
looks great! how did it work (well.., crappy, better than expected, not mounted yet?)
Old Nov 8, 2008 | 07:33 AM
srosa75's Avatar
srosa75
Serious question. Will the headlights work if you bypass the vacuum tank completely?
Old Nov 8, 2008 | 07:39 AM
'75's Avatar
'75
Yes
Old Nov 8, 2008 | 07:46 AM
1nicecorvette's Avatar
1nicecorvette
what exactly is the purpose of the vacuum tank? if there is always a vacuum coming from the manifold it obviously doesnt hold air.
Old Nov 8, 2008 | 07:51 AM
'75's Avatar
'75
There should be a check valve to hold vacuum in the reservior after the engine is off, that way you would be able to lower the headlights.
Old Nov 8, 2008 | 08:13 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Why steel, I think aluminum would be trick.
Hey is Leesville still a speed trap? I got nailed for doing 63 in a 55 and had to go before the judge.
Old Nov 8, 2008 | 09:04 AM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Old Nov 8, 2008 | 09:24 AM
Durango_Boy's Avatar
Durango_Boy
I seem to remember that the tank's purpose is to hold enough vacuum to operate the headlights one time after the engine is shut off.
Old Nov 8, 2008 | 09:43 AM
7T1vette's Avatar
7T1vette
It's also a good thing to have when you go WOT (no vacuum level), but need to hit the power brakes quickly. The tank maintains vacuum level when engine conditions don't provide any. You also need the check valve in the system so that the tank won't leak down.
Old Nov 8, 2008 | 10:04 AM
Durango_Boy
I didn't think the brake vacuum lines had anything to do with the headlight vacuum system with the exception of the vacuum tree on the manifold, in which case the vacuum from the tank would nothing to do with the brakes.
Anyone know for sure?
Old Nov 8, 2008 | 10:32 AM
'75's Avatar
'75
Yeah, check valves seperate the brake and headlight vacuum.
Old Nov 8, 2008 | 11:25 AM
Red70vette's Avatar
Red70vette
Congratulations!!! You are bringing Bubba to a whole new level. You did a very nice job there but wouldn't it have been easier to buy a new one for $40 bucks or a good used one for about half that?
Old Nov 8, 2008 | 12:34 PM
1nicecorvette
there is only the one check valve with the two two outlets and one inlet the end correct?
Old Nov 8, 2008 | 09:28 PM
earthquake68
My Eckler's catalog says $60 plus tax and shipping. This was $35 total. (and it's twice the size) My headlights should never drift up with a reservoir this size.
Also, I don't especially like the term "Bubba" in referance to my work. I'm a fabricator. I wouldn't consider hand forming sheet metal quarter panels "bubba work". If I really cared what this piece looked like, I would have spent more than the 30 minutes I did to make it, and finished it off so it was indistinguishable from a factory piece. I don't mean to sound snooty, I really don't. ...but after today, comments like this will get under my skin. I'm a hotrod builder/fabricator with 30+ years at turning wrenches. I'm no $9/hr backyard hack. Again, I'm not really that upset at anyone here, I had a customer rub me the wrong way today, and I appologize in advance for being salty. Thanks for the kind comments everyone. I'll let you how it works after I get it installed tomorrow.
P.S. I also make my own mufflers, repair panels, interiors on occasion, steering wheels and what ever else needs to made and can't be bought.
I also just thought up a turbo muffler that'll fit inside a 4" tube for side pipes. I'm gonna make the headers and mufflers for my Corvette and I'll let you know how they turn out.
To There, how's this? (pics)
Old Nov 8, 2008 | 10:01 PM
...Roger...'s Avatar
...Roger...
I've made a dozen tanks out of 3 lb. coffee cans and several out of 3" pvc but I put in 3 nipples and one of these right at the tank. http://www.usplastic.com/catalog/var...riant_id=64175
Last edited by ...Roger...; Nov 13, 2008 at 07:52 PM. Reason: wrong link to check valve
Old Nov 8, 2008 | 10:09 PM
earthquake68
Originally Posted by DWncchs
I've made a dozen tanks out of 3 lb. coffee cans and several out of 3" pvc but I put in 3 nipples and one of these right at the tank. http://www.usplastic.com/catalog/var...riant_id=64001
That's a good idea. This is made out of 14 gauge steel. The nipples are actually two differant sizes. The bigger one will be t'ed and go to the actuator relays, the smaller one will go back to the manifold. The check valve should insure me to operate the headlights a few times with the engine off, ....if I need to do that.
Old Nov 8, 2008 | 10:26 PM
Durango_Boy
Not sure I agree, and I certainly wouldn't call what the OP made a Bubba tank. It's actually a well thought out project that took very little time and money and will work just as good or better than the stock tank.
Bubba probably would have used a couple 2 liter bottles Duct taped together.
