Help - 77 Engine Compartment Paint
1. Can anyone tell me what color (ie flat, semi flat, semi gloss etc) black the painted areas of the firewall, interior of fenders and underside of hood should be painted?
2. What parts of the firewall, interior of fenders and underside of hood should be painted and what areas should not be painted.
3. Any recommendations of specific brands of paint and sources?
If anyone has any detailed pictures that they would like to post or email me, I would appreciate it.
Thank You
Troy
troy.blackburn@advanteck.net
Pictures from my earlier thread...
http://forums.corvetteforum.com/c3-g...ngine-bay.html
Another over the counter is the John Deere Black blitz. I've used it and its a near match. These paints will appear more like flat than semi-gloss but you've got to discount the label description.
A mask was used to protect the painted hood while the entire underneath side of the hood was painted. So the hood was hinged but the hood support was not installed.
Once black-out was completed, the entire vehicle went through a baking oven...so you can see no other wiring harness or parts were installed at this point. As you work, think like a factory worker.
A suggestion would be to pick up the NCRS technical reference guide for 75-77 which lists the colors for all areas of a Corvette and in great detail. The NCRS tech forum would be another source to search for threads on the black-out operation.
