*Random C3 Project Pics Thread*
Old Nov 23, 2008 | 06:14 PM
DEMITRISTYLES's Avatar
DEMITRISTYLES
From: You Can't Buy Cool, No Friggin' Way - Mississauga Ontario
Default *Random C3 Project Pics Thread*
I just like seeing all of your projects, so I thought I'd start a thread where you can post them all...go!
Old Nov 23, 2008 | 06:41 PM
Gordonm's Avatar
Gordonm
Here is my projects at the moment. Rear out, updating to a stronger stub axles. 1 has a slight twist. Transmission is out for an update and just finally got around to installing the Steeroids.
Here you can see the rear on the workbench.
Old Nov 25, 2008 | 12:56 AM
GPGG70's Avatar
GPGG70
Got the old original harrison radiator out and cleaned up the support and crossmember and ran out of time before having to go to work.
Next is the While I'm At It, going to redo the A-arms and bushings, install new springs, and redo the front steering, then once that is finished reinstall my new Dewitt radiator. Once the front end is buttoned up I'll replace the heater core. Then after that I'm sure I can find something to do on the rearend.
Old Nov 25, 2008 | 01:47 PM
tfi racing's Avatar
tfi racing
Had to roll this out when I moved in March,hopefully it will be rolling into the new garage I'm building by Christmas...
Old Nov 25, 2008 | 05:40 PM
vettekid333's Avatar
vettekid333
2024 C3 of the Year Finalist - Unmodified
ARE THOSE CIRCLES AROUND THE HALF SHAFTS THERE TO KEEP THE SHAFTS from damaging everything should they break? Looks like you have beefed up everything.
Old Nov 28, 2008 | 10:42 PM
DEMITRISTYLES
Yes
Old Nov 29, 2008 | 03:39 AM
vettebuyer6369's Avatar
vettebuyer6369
Hmmmmm.... project...
Old Nov 29, 2008 | 10:21 AM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
This was the last major project done this past summer. This all began when I went out to the garage just to check air pressure in the tires.........
...........Oh yea, I did the complete exhaust too..........
Old Nov 29, 2008 | 01:10 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Great idea for a thread. Hopefully I can get down there and install the rear strut rods that have been on my shelf for the past few years.
I really like Gordon's drag hoops. This could save some damage if something should happen while playing. Adding this one to my list of things to do someday.
Keep the ideas coming guys.
Old Nov 29, 2008 | 03:43 PM
jlaw68's Avatar
jlaw68
how hard was it to install the steeroids setup?
Old Nov 30, 2008 | 11:04 AM
Gordonm's Avatar
Gordonm
Actually very easy to install. If you have headers they will need to come off to get the old steering box out but other than tha tvery easy. I just dropped the whole system but the steering box then dropped that. Once cleaned up it takesvery little time. I have not fired it up for obvious reasons but it should just be a fill of fluid and ge tall the air out of the system.
As for the loops. They were part of the 6 link system but can be purchased seperatly. Strictly for safety reasons. Another reason I did the 6 link so that if the shaft does let go I still have control of the rear. The half shaft is no longer a stressed suspension member. I do not even have the snap rings on the stub shafts.
Old Jan 2, 2009 | 11:02 PM
DEMITRISTYLES
Next?
Old Jan 2, 2009 | 11:19 PM
SuprJames's Avatar
SuprJames
My next project is to install the PCV catch can as soon as I get her back from the alignment shop. Then it is more wire tidying up and latching down the battery and computer. The projects are getting smaller!
Old Jan 2, 2009 | 11:25 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
Default 69 Radiator & Front Suspension Rebuild
The plan is to install a new DeWitt's Radiator. Sent the radiator shroud and lower support out for powdercoating. Got new hoses and seals from Dr. Rebuild
I should have the front suspension/steering completely out for powdercoating and new bushings, ball joints and tie rod ends. Whatever fits in my 30" oven will be powdercoated.
It's all fun!
Also have the simple task of replacing the heater core! YEEHA! Glad this one doesn't have AC!
Old Jan 2, 2009 | 11:48 PM
Retro78's Avatar
Retro78
This year is a 3" year. Installing these, including 3" driveshaft, 3" half shafts with solid spicers, 3" exhaust after the trany is in.
Old Jan 2, 2009 | 11:54 PM
RobRace10's Avatar
RobRace10
Here is my project of the moment rebuilding the 427 BB. Got the bottom end back from the builder. so painted the block, pan and chain cover, installed the new cam, lifters and Coyes. Also order lots of parts this week to complete. Next week I'll take the heads in for some port work.
Old Jan 3, 2009 | 01:02 AM
MN-Brent's Avatar
MN-Brent
New 700R4 with 2K stall - New 3.07 Rear End - New Trailing arms - New rear spring - Cutting front coils - 1.6 Roller Rockers - Lots of little detail work
To *Random C3 Project Pics Thread*
Old Jan 4, 2009 | 01:03 PM
in2fun's Avatar
in2fun
I just installed my L88 hood on my 72. I bought the hood used. I stripped the 6 layers of paint it had on it, then I installed it on the car to make sure it fits good before I spend the $$$ to get it painted.
Now I'm having a hard time desiding how to match the strips I have on the car. Here are some pic.
Old Jan 4, 2009 | 01:31 PM
Joe0121's Avatar
Joe0121
St. Jude Donor '06
Great thread
Old Jan 4, 2009 | 01:47 PM
Bowerss2's Avatar
Bowerss2
Engine in my 1980
