Engine dress-up help
Old Nov 29, 2008 | 07:02 PM
Alan 71's Avatar
Alan 71
Hi V5869,
You're absolutely right about the search and the $$$.
What I should have added is that stock is relatively cheap IF you have a VERY complete car in fairly good condition.
I guess what I type is not always what my mind is thinking.
Regards,
Alan
Old Nov 29, 2008 | 08:07 PM
vettebuyer6369's Avatar
vettebuyer6369
Originally Posted by Alan 71
Hi V5869,
Regards,
Alan
Ha, don't feel like the Lone Ranger... I rarely trust what I type the first time around.
Old Nov 29, 2008 | 09:01 PM
C3 4ME's Avatar
C3 4ME
Miles, I did mine without taking the engine out. It looked very haphazard before, which yours does to me as well. Please dont take that wrong, it's just constuctive criticizm. I bascially took everything off the engine and painted it, then covered the engine and did the compartment. Lots of aluminum foil was wrapped around lines a wires, and lots of taping and covering of the larger pieces.
Old Nov 30, 2008 | 12:23 PM
hobbycarcorvettes's Avatar
hobbycarcorvettes
1974 Red Corvette before and after!
Old Dec 14, 2008 | 08:33 PM
SEVNT6's Avatar
SEVNT6
I hid the lines for the headlight doors under the brake booster. Took out the washer bottle & all lines. Filled & smoothed the firewall. I wanted to keep the stock look but also add some bling......
Old Dec 14, 2008 | 09:24 PM
BassCat's Avatar
BassCat
If you take your time, you can paint and clean up the engine bay without removing the motor. For painting, those small wooden handle foam brushes at wal mart work great. Just spray the brush from a spray can and paint those hard to reach areas. I cleaned my engine bay up with the motor in. I'm not finished, but it looks a lot better than when I bought the car. The sky's the limit on dressing up these old V8's. Tons of chrome and polished aluminum parts available. To me, this is one of the most fun parts of owning one of these old cars, dressing up the engine. Good luck, and have fun with it.
KC
Old Dec 15, 2008 | 07:45 AM
corvetteload's Avatar
corvetteload
dr rebuild has spark control line diagrams, get a catalog or check online
Old Jan 6, 2016 | 07:48 AM
bobs76stingray's Avatar
bobs76stingray
Default Dress-up
Originally Posted by randommj
well, Im thinkin of replacing all my vacuum lines, radiator hoses and the like, (big job I know ) durring my christmas break, and asking for the stuff to do it for chirstams, anything else you see that would help make the engine pop out a little more (aside from a 502)
edit* Oh and if anyone knows where to find a stock 74 L-48 vacuum hose diagram, Im sure Ive got a few that are misplaced, that would be great!
Miles
My suggestion would be to look on the forume for the other members enginebays.The members here love to show-off there cars and the work they have done to their Vettes,and have every right to do just that.That is what this forume is all about,All the members here will bend over backwards to make their Vettes look awsom,and when you start looking you will find some truly awsom owners with awsom talent.So look around,I know you will find everything you are looking for.
Just my 2 cents worth.
Old Jan 6, 2016 | 07:54 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Bob, you've pulled up a thread from 2008.
Old Jan 6, 2016 | 11:20 AM
Tbone4432's Avatar
Tbone4432
Default Wires
Originally Posted by Ironcross
Buy another set of plug wires with 90 degree plug boots and run the wires underneath the manifolds/headers up the back along the bell-housing to the distributor cap. That yellow octopus has to go. It looks like it attacked your engine with the 8 tentacles grabbing the engine. Underneath the wires are out of sight and out of mind.. Works for all engines with the distributor in the back....
Yeah, what ironcross said. My pic isn't the best, but I did what iron said. I bought wire boot protectors to protect the boots from the headers.
Old Jan 6, 2016 | 02:06 PM
red topless gator's Avatar
red topless gator
Another 74 before and after
