Math question, thermal dynamics
Old Dec 3, 2008 | 01:59 PM
Jay-Dog's Avatar
Jay-Dog
OMG, you guys are total geeks!
Old Dec 3, 2008 | 04:50 PM
V77Vette's Avatar
V77Vette
yea but dont the He slowly leak out because of the low mol rate (He=2)
Old Dec 3, 2008 | 05:41 PM
stingr69's Avatar
stingr69
P1 / T1 = P2 / T2
The pressure and temperature should be in absolute units.
The Volume will be assumed to be constant for convienience.
If you know P1, T1, and T2 then just do the math and get P2.
42.7 PSIA / 480 degrees Rankine = x PSIA / 530 degrees Rankine
SO... I get x=47.15 PSIA so we subtract 14.7 PSI to get to 32.5 PSIG
-Mark.
Old Dec 3, 2008 | 06:06 PM
...Roger...'s Avatar
...Roger...
Isnt great.
Old Dec 3, 2008 | 07:29 PM
toddalin's Avatar
toddalin
Actually you go by the molecular weight and atomic weight of helium is 4 (two protons and two neutrons). But you are correct in that it is a relatively small atom and over time can pass through the rubber, though not as much as hydrogen.
I think that tire places hype nitrogen and say it doesn't change pressure as much as air is due to the water vapor in the air they pump. When water flashes to steam, it expands 1,800 times. Thing is, there really shouldn't be any water vapor in their air.
Old Dec 3, 2008 | 07:59 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Originally Posted by toddalin
The type of gas has no bearing on the equation.
Except for the compressibility factor, which you happened to leave out. Unfortunately, I don't have DIPPR on this computer, so I can't look that up for you.
The amount of water that would be in any normal compressor is so minimal, I doubt you would notice.
And unless it is a record temperature day outside (ooh somewhere around 212°F) I wouldn't expect that flashing (except maybe at the outlet nozzle briefly before condensing again).
So don't fill your tires with water people!!! Global warming could lead to your tires exploding! (I hope I just opened a whole new can of worms )
Old Dec 3, 2008 | 08:39 PM
454_71Stingray's Avatar
454_71Stingray
Originally Posted by 74Blackfoot
What's wrong with waiting until it's 70* outside and checking the tire pressure?
Because I dont have an air compressor where/when it is 70, I have one where/when it is 28.
Old Dec 3, 2008 | 10:17 PM
toddalin's Avatar
toddalin
No compressability factor in the ideal gas constant.
Recognize that as a tire, or anything heats up, it does not heat up perfectly evenly and the temperature represents an average fo the molecules. But some molecules are hotter while others are colder.
When a tire spins and builds up heat, it is certainly conceivable that some of the molecules could reach 212 degrees F and flash to steam if water vapor is present. And I've seen plenty of air compressors give a nice wet shot of air.
Old Dec 3, 2008 | 10:57 PM
LeMans Pete
I'm sorry, this is all rediculous, yet I can't seem to walk away. Unfortunately, in the real world, there is compressibility. It is not ideal.
First we were talking about water in a compressor flashing on discharge, now we're talking about spinning tires? So we've gone from a temperature change from morning to afternoon, to tempertaure change from somebody spinning their tires. So they have to spin the tires long enough that it heats up the inside (you got heat transfer through 1/2" of rubber) of the tire to ~275°F because your tire is under pressure to vaporize the small amount of water thats might be in there?
This is rediculous. This is blown out of proportion, and I know I'm not helping, but I can't.... seem.... to... stop...!!!
Old Dec 3, 2008 | 11:22 PM
DaJesterMan's Avatar
DaJesterMan
I think what he meant was the tire heats up as it flexes... like when you drive at very high speeds and pull over, reach down, and feel a hot tire... I just don't know if that would get up too over 212, which it would need to. At 30 psi (~ 2x ATM), phase change from liquid to steam happens at 250 deg F... (according to my trusty steam tables) Do tires get that hot?
Old Dec 4, 2008 | 12:55 AM
lowbuck72's Avatar
lowbuck72
You all need to change the subject...
Speaking of thermodynamics, over at Home Depot, you can't buy any laminar flow, the only flow they have is linoleum or wood.
Old Dec 4, 2008 | 08:51 AM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
If I am going to drink a relatively light domestic beer, like a regular budweiser, I like it best around 29-30 degrees farenheit, almost freezing. But, if I was going to go with something like a Sam Adams or Brooklyn Lager, I would be more interested in 42-45 degrees. I think this may have something to do with the compressability of the water vapor in my tires, but I am not sure.
Old Dec 4, 2008 | 09:07 AM
  #33
LeMans Pete
So we're talking about normal driving, that tires are going to heat up to 200+°F? Unless you're doing burnouts, your tires should never reach that temperature.
Also, are we talking 30 psig or 30 psia? I would assume guage since that is what you'll be measuring, meaning you'll be closer to 275°F (http://www.spiraxsarco.com/esc/SS_Properties.aspx).
Old Dec 4, 2008 | 09:11 AM
  #34
DaJesterMan
yeh good point, it would be gauge... either way, if the tires are getting that hot, it can't be good!
Old Dec 4, 2008 | 11:14 AM
  #35
stingr69's Avatar
stingr69
Who does burnouts?
That was confusing. The qualifier was the "2x ATM". Standard ATM is 14.7 PSIA. 2x ATM is about 30 PSIA but that is only 14.7 PSIG. Burn outs are much harder with only 15 PSIG in the tires. Not that I actualy DO burnouts.
-Mark.
Old Dec 4, 2008 | 12:12 PM
  #36
jnb5101's Avatar
jnb5101
i'm glad someone stayed awake in physics!
Old Dec 4, 2008 | 05:51 PM
  #37
PRNDL's Avatar
PRNDL
I use a special patented blend of gases in my tires to achieve the ultimate in performance.
Start with 78.1% Nitrogen, blend in 20.9% oxygen, and top it off with .9% Argon for
stability and a smidge (.1%) carbon dioxide and some traces of other rare gases.
I can send you a tube if you like.
Old Dec 4, 2008 | 06:14 PM
  #38
LeMans Pete
Dibs!
