Dates for 70 LT1...HELP...
Old Dec 3, 2008 | 09:04 PM
vettesbydesign's Avatar
vettesbydesign
Default Dates for 70 LT1...HELP...
This is a Febuary(B) build date.Missing the correct heads,and intake.They were stolen.All the other parts are there,but need to know the range that are acceptable for the heads,and the intake.The heads could be 186s,or 414s right?
Thanks for any imput,and help......Then the next question......you have these for sale???
Old Dec 3, 2008 | 09:20 PM
dennis's Avatar
dennis
Right on the numbers. 6 month window, I try to stay close if possible. If I remember, there was a post on the NCRS or resto forum here. Guy had a set of late 69 186's. Small valve though. You'd need to enlarge. I'll see if I can find it
Old Dec 3, 2008 | 09:22 PM
dennis's Avatar
dennis
here's the post
http://forums.corvetteforum.com/fact...der-heads.html
Old Dec 3, 2008 | 10:07 PM
vettesbydesign
Thanks for the link!!!
one of Billas heads were from Aug.68 tho, for a 69 car,and the other was a Nov.69 for a 70.
I will try to contact Hurri,and Mako,and see what they have.
Thanks again....
Old Dec 4, 2008 | 08:33 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Six months prior to engine assembly date is acceptable. Closer is better. My '68 small block was assembed on April 9th and has an April 1st casting date. One head was cast on March 28th; second was cast April 3rd. Intake cast on April 1.
Do not use the Time/Build date on the trim tag. The original engine had already been assembled and shipped to St. Louis by that date. Use the engine stamp on the block and date your parts accordingly.
Old Dec 4, 2008 | 11:40 AM
joewill's Avatar
joewill
yes, also watch out for too close of a date, I have seen a casting date of march 5 of the block, and engine assemble date of march 20, an intake manifold date of march 25 and car build date ( trim tag) of april 15..
these are all before the trim tag date.. and seemingly OK, but the manifold was cast after the engine assembly date.... that can't happen....
Old Dec 4, 2008 | 12:11 PM
vettesbydesign
Thanks fellas for the thoughts.The trim is Feb.11th,1970,and the engine is A/15/0,and the heads now are J/1/9,and J/10/9.The carb is #3972121/list 4555,and dated 054..
Thanks...Kevin
Old Dec 4, 2008 | 01:09 PM
Easy Mike's Avatar
Easy Mike
...the engine is A/15/0...
That's a casting date. Engine assembly date on the pad will have to be after January 15th. Just the same, a January 15th casting date for a car assembled in early February is pretty good.
Old Dec 4, 2008 | 01:35 PM
mstanton's Avatar
mstanton
Here's the info for my 70 LT-1:
Trim Tag: B24 Feb 24
Engine pad: V0203 Feb 3
Heads: 22 Dec 69 and 6 Jan 70 both 186
Old Dec 4, 2008 | 03:11 PM
vettesbydesign
Thanks fellas.This helps alot.
Merry Christmas ya all...
To Dates for 70 LT1...HELP...
