81 blinker problem
Old Dec 8, 2008 | 10:00 PM
corvette8189's Avatar
corvette8189
Default 81 blinker problem
81 corvette
when turned on, the lights just light up thats it. nothing shows on the dash either. brand new bulbs in rear and blinker fuse.
Thanks for any help
Old Dec 8, 2008 | 10:09 PM
STINGRAY1WORD's Avatar
STINGRAY1WORD
What about with the hazard lights do they flash?
Old Dec 9, 2008 | 07:47 PM
corvette8189
yes the hazard lights work, but nothing shows on the dash
Old Dec 9, 2008 | 09:36 PM
corvette8189
anybody know?
Old Dec 10, 2008 | 09:28 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Brake lights work?
Old Dec 10, 2008 | 09:30 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
What about the flasher unit "square or round 2 pin connector" Ron
Old Dec 10, 2008 | 09:44 AM
...Roger...'s Avatar
...Roger...
I would guess a ground problem on the no blinking or a bad flasher.On the no dash indicators that could be a separate issue maybe bulbs burned out or the common between the 2 bulbs is ground or the printed circuit plug.Also usually if the poor ground is found for the front signals the turn indicators will come on when the parking lights are on-does this happen?
For the flasher to flash it needs a load of a couple bulbs-burned bulbs will create NO load as will an ungrounded bulb or socket.(i doubt that burned out dash indicator bulbs would lighten the load enough to cause the flasher not to flash but that would be a common to tie all your problems together)
Old Dec 11, 2008 | 06:31 PM
corvette8189
Brake lights work?
yes the brake lights work
round flasher unit
when blinkers turned on the front just light up and the backs do nothing
Old Dec 11, 2008 | 09:31 PM
...Roger...
Thats different......turn the left signal on and using a 12 volt test light probe the yellow wire on both sides of the harmonica connector...let us know if that makes the left flasher work.
Old Dec 11, 2008 | 10:07 PM
corvette8189
whats the harmonica connector. and i use a 12 volt battery
Old Dec 13, 2008 | 10:13 PM
corvette8189
ttt
Old Dec 14, 2008 | 03:32 PM
...Roger...
The harmonica connector is a long flat connector usually attached to the side of the steering column and connects the turn signal switch to the dash harness.All your turn signal wires go up to the switch and come back down.Sounds as if you might have a turn sig. switch that has failed.
To 81 blinker problem
